Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: is this pinion 48p?
Old 04-06-2008, 11:56 AM   #1
Default is this pinion 48p?
i found this and checked a couple of places to see if i could find any specs. on it but no luck... so im asking yall!
http://www3.towerhobbies.com/cgi-bin...?&I=LXMRG2&P=7
goobs is offline   Reply With Quote
Old 04-06-2008, 12:23 PM   #2
1rcmonster's Avatar
the smallest 48 pitch pinion i seen on tower was a 12 tooth.....just put 48p pinion in their search...the one u show looks to be 32 pitch....
1rcmonster is offline   Reply With Quote
Old 04-06-2008, 12:35 PM   #3
Picky Fab'r/Acetal Junky
Offroader5's Avatar
It may very well be 48p because of the smaller bore. That fits a small 2.3mm shaft and not the standard 1/8" (~3mm) shaft.
Are you looking for a gear for a 540 sized or similar....or something smaller like 1/18 scale?
Offroader5 is offline   Reply With Quote
Old 04-06-2008, 12:38 PM   #4
That looks to be .5 module that is common on heli's. It is way too small for a crawler, unless you're running a mini-T or 18T.
jdmstuff is offline   Reply With Quote
Old 04-06-2008, 01:13 PM   #5
yeah im looking for a 540 sized pinion!
i have a 12t on my rig already and was looking for something smaller.
Old 04-06-2008, 01:18 PM   #6
Smallest thing I could find was a 12T 48p. RobinsonRacing if I remember correctly. I went to a 90T spur (on an AX10, not sure what you;re running.) People have said you can get a larger spur than 90t on there, but mine barely clears the output shaft.
rdtshaw is offline   Reply With Quote
Old 04-06-2008, 01:47 PM   #7
I think a 12tooth pinion in 48 pitch is going to be the smallest readily available. I could have sworn that I've seen a tooth or two smaller, but can't remember where.
You could always try to up the spur gear size to get the same effects as shrinking the pinion. Unless you're out of space already.
Cake Eater is offline   Reply With Quote
Old 04-06-2008, 04:30 PM   #8
Why? - are you wanting to go really slow - consider going to a higher wind motor - if you're running a 55 - consider a 65 - I've never seen anything smaller than a 12t.
Yawzer is offline   Reply With Quote
Old 04-06-2008, 05:42 PM   #9
i have a 96t spur and a 12t pnion on my pti goliath w/ a 55t motor.
and i know that rc4wd has a 10 or 9t pinion.
just trying to find the smallest... with out having to spend a lot on a gear reduction.
but nobody has answered my ? yet... is that pinion a 48p?
Old 04-06-2008, 05:48 PM   #10
http://rc4wdstore.com/index.php?cPath=37
Robb is offline   Reply With Quote
Old 04-06-2008, 06:14 PM   #11
TEAM MODERATOR
Reflection's Avatar
12/96 running a 55t.....and you want lower
14/81 running a 35t on a 3 cell lipo is barely fast enough.
Running gear reductions is SOOOO 2004.
Probably is a 48p,but I can't say for sure. BUT.....
It won't fit a standard 540 motor shaft.
Reflection is offline   Reply With Quote
Old 04-06-2008, 06:17 PM   #12
I think the only answer I saw is that it might be, but it wouldn't fit a 540 motor shaft anyways (without milling the shaft down). And that it's going to be way too small for a crawler... It's only 9.4mm long. Take into account the set-screw (you can't mesh that with the spur) and it's only has a contact point of half that.
But if you need some sort of definite answer, try emailing Heli-Max for the info.
I think the consensus is that it wouldn't work and that you should consider other options.
*EDIT* raptorman beat me too it. I agree with him, too.
Old 04-06-2008, 07:03 PM   #13
If you want it slower, switch over to 32p gears. You get alot more gearing choices.
LST022752 is offline   Reply With Quote
Old 04-06-2008, 08:01 PM   #14
9 tooth 48 pitch: http://www.hobbyetc.com/cgi-bin/item.cgi?part_id=35989
10 tooth: http://www.hobbyetc.com/cgi-bin/item.cgi?part_id=35927
11 tooth: http://www.hobbyetc.com/cgi-bin/item.cgi?part_id=35928
12 tooth: http://www.hobbyetc.com/cgi-bin/item.cgi?part_id=54147
Package of all 4: http://www.hobbyetc.com/cgi-bin/item.cgi?part_id=32742
I haven't tried any of these yet. The space between the teeth and end that will go closest to the motor looks to be rather large, so some might have problems getting them to fit. I guess you could space out your spur gear if you needed clearance.
gr33nlemon is offline   Reply With Quote
Old 04-06-2008, 08:17 PM   #15
TEAM MODERATOR
Reflection's Avatar
How do you figure that?
Old 04-06-2008, 10:17 PM   #16
the pti doesnt have a tranny, its direct drive. and its pretty fast...too fast!
a gru is my only way to go slower and get more torque w/o changing up my whole set up.
anyways thanks for the help guys!
i'll probably email heli-max and see waht they say.
probably just end up gatting a gd-600.
Old 04-06-2008, 10:27 PM   #17
Nice, I saw something like this before, but it was for 18th scale...
Old 04-06-2008, 10:37 PM   #18
Why?
If a 8T will do you great, a 9T will do you just fine. gr33nlemon linked above to a 9T that will "bolt on" directly to your motor, whereas the 8T of the Heli (if it is 48P), will require milling down your motor shaft to be able to fit. The 9T is a couple of bucks more, but for the ease, it seems like the logical solution.
Old 04-06-2008, 10:53 PM   #19
sloppy's Avatar
not mention it looks like a brass pinion. that will hold up great
sloppy is offline   Reply With Quote
Old 04-07-2008, 06:44 PM   #20
TEAM MODERATOR
Reflection's Avatar
If there is no tranny,and it's direct drive.....what the hell are you mounting the 96t spur to and what will you be mounting the GD600 to?
Direct drive........a 55t should be just right for that
