| | #1 |
| Search Button Nazi ![]() Join Date: Jan 2008 Location: Calgary, AB, Canada
| OK, I just finished setting up my crawler and it doesn't have nearly enough power, I think. Here's the specs from my post in member's rides. Chassis - Unitek Spider (on EBay) - Made from ¼" lexan Suspension - Came with chassis - Solid aluminum 4 link - Shocks unknown, comparable to stock T-Maxx shocks Axles - Came with chassis - Machined from solid T6061 Aluminum - Hardened stainless steel axleshafts and internal gears Gearbox - Came with chassis - Case machined in T6061 Aluminum - Hardened stainless steel internal gears Driveshafts - Came with chassis - CV slider shafts made from Aluminum and hardened stainless steel Wheels / tires - Axial narrowed beadlocks / Losi rock claws ESC - Novak Rooster crawler edition Reciever - Traxxas 3 channel micro receiver Transmitter - Traxxas TQ 2 channel Motor - Novak high torque expert 55T Servo - Hitec HS5645MG, aluminum servo arm and custom draglink steering Wheelbase - 17" Ground clearance - 2 3/8" at lowest point (center of axle) - 3 3/4" at center of chassis Width - 16" outside of tires - 11" hex to hex Height - 8" to top of chassis without body mounts - 10" to top of body It's a pretty large rig (slightly bigger than my Savage X) and when I try to crawl up stuff it just doesn't get very far. It's not a traction issue, the wheels just stop turning. I'm running it on a 6cell 2200 MaH Ni-Cd battery. My question is, what wouold be the ideal battery set-up for the ESC I have in it. In the manual it says not to run more than 7 cells so I'm guessing Li-po is the way to go. I don't want to waste money trying different set-ups and definitely don't want to mess up my ESC. Any reccommendations? |
| Sponsored Links | |
| | #2 |
| TEAM MODERATOR ![]() Join Date: May 2004 Location: Tennessee
| Only being able to run 7 cells kindly hurts a guy looking for more power. Pretty lame,IMHO,to build an ESC thats 7 cell max. You'll be limited to a 2 cell lipo if you wanna go that route. You won't have any more voltage than you have now. Running 7 cells,you could go with a 5,7 or 10 turn puller. They will crush your 55t,or any 540 sized motor for that matter,in the power dept. You can gear it down for more power,but with only 7 cells,you won't be able to volt up to get any speed out of it. If you want more voltage,go Castle. IMHO,Castle ESC's are the best option for crawlers. WAY to many options and benifits running Castle stuff. If you run a Castle Creations ESC,you could throw a 3 cell lipo to that 55t and wake it up a bit. Even better,rewind it to a 35t and run a 3 cell. Last edited by Reflection; 04-06-2008 at 08:38 PM. |
| | #3 |
| Keep it real ![]() Join Date: Jun 2006 Location: Yakima,WA
| Yeah, definitely a motor and voltage issue. |
| | #4 |
| That's what I was afraid of, guess I'll have to build a smaller rig for my Novak and get something a little more capable for this rig. Can't quite yet but it's in the works. Thanks for the advice, as much as I didn't want to hear it. |
| | #5 |
| Another option with the Novak, is to pull the red wire from the harness, and run a BEC or voltage regulator, then you can run more cells. But I think you will still be way underpowered with the 55t |
| Thread Tools | |
| Display Modes | |
