Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: new dig
Old 04-07-2008, 12:09 AM   #1
Default new dig
here is a new dig setup that I made and I haven't found anything much like it here on the forums so I thought I'd post it
I won't try to explain it, I'll let the pictures do the talking
Feel free to ask ?'s
stublet is offline   Reply With Quote
Old 04-07-2008, 01:27 AM   #2
That's an interesting idea. So the female section spins inside the sheetmetal section and the screws brake against the splines of the male section at the pinion end, right? Does it work well? I see you're getting some use out of the TP servo. Also, how do you like it since you went droop?
chrisjlittle is offline   Reply With Quote
Old 04-07-2008, 08:16 AM   #3
right, there are two female sections, one fixed(with screws) and the other free to move with the driveshafts when engaged
tower pro works great for dig
Old 04-21-2008, 12:44 AM   #4
any feedback/ suggestions on the setup
Old 04-21-2008, 10:53 AM   #5
Scale Jedi
muddauber7's Avatar
I've tried that way before, and couldn't stop sheering the drive-shaft where you have to turn it down for the "free wheel" portion of the dig. Even having an 1/8" rod JB'd into that side of the assembly. I have since changed my design, and am causing others in our local club to even sell there R2D's, after having a chance to drive my new set-up. And I'm still using a 225mg and having no issues. It's all in the set-up and tuning.
muddauber7 is offline   Reply With Quote
