Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: new idea for artificial course....
Old 04-09-2008, 03:29 PM   #1
Default new idea for artificial course....
ive seen a bunch of ways to build artificial courses. heres an idea im going to try here soon. should work great. instead of goin the xpensive route of using line-x to coat the obsticles, i run a used tire shop and there is a water based rubberized paint that we use to paint the old tires to make them look new. its been around for a while but im going to coat some of the obsticles that arent actual rocks with it and it is way cheaper than line-x! you can buy it in 5 gallon buckets and dilute with water so it will go along way. just another option. you should be able to buy it online or from a large local tire distibutor. i will try and figure out how to post pics here soon. im converting a large part of my back yard. ( no wife to ask permission)
4ONDFLR is offline   Reply With Quote
Old 04-09-2008, 03:38 PM   #2
sounds pretty sweet
toomessedup is offline   Reply With Quote
Old 04-09-2008, 03:45 PM   #3
Gold Star Baby!
Stormin2u's Avatar
Location: Taylors Falls just hanging with the MNRCRC crew.
Lets us know how it works.
Stormin2u is offline   Reply With Quote
Old 04-09-2008, 06:19 PM   #4
Rockpiledriver's Avatar
In the past we covered the linex with elastomeric paint. It is a rubberized paint that sound pretty close to what you are describing. Without the spray on bed liner there was not even close to enough protection for the foam. The crawler tires themselves were able to tear right through it.
But hey, give it a shot and see if it works.
Rockpiledriver is offline   Reply With Quote
Old 04-10-2008, 12:20 PM   #5
I used race gas trucks on a track in spokane that had that stuff on the track,Crazy traction but when you walked out on the track you had to be carfull not to rotate youre foot with youre weight on it ar it would rip the suface.So durabilty could be an issue.
rockmike is offline   Reply With Quote
Old 04-10-2008, 01:55 PM   #6
I used concrete... much more natural then Linex or anything along that lines
I have pictures some place
Jeepernick is offline   Reply With Quote
Old 04-11-2008, 06:47 AM   #7
You can buy something like that at walmart. Kinda like a roll on liner. Get you some foamlite concrete, rebar, and chicken wire. Bend up the rebar and wrap with chicken wire. Then you coat it with this lite weight concrete. You can make a rock and it weighs half as much!
crawlbe4youwalk is offline   Reply With Quote
Old 04-11-2008, 09:19 AM   #8
I dunno, I'm not so sure I'd want a rubberized surface on my entire course. Even if it's an artificial course, that's a little too artificial. And why coat the objects that are not rocks? It's not like a black rubber surface will make them any more like real rocks. It may give more traction, but isn't that cheating, just a little?
If it's an outdoor course, I'd build up some forms out of wood and chicken wire and slap a couple coats of concrete on 'em.
Mad Scientist is offline   Reply With Quote
