| | #1 |
| Quarry Creeper Join Date: Jul 2004 Location: 808
| Im thinking about building a custom crawler and wanted to know opinions on trannys? What do YOU think is the best and why? At first I was thinking about an e-maxx tranny so I could have the 2 speed, but after thinking about it I want to use independant 4ws and I only have 3 channel radios...so I wouldent be able to shift anyway. And please dont tell me clod trannys...I already have a clod (and love it) but I want to experament with a drive shaft truck.. |
| Sponsored Links | |
| | #2 |
| TEAM MODERATOR ![]() Join Date: May 2004 Location: Tennessee
| I'm going to put a Maxx tranny in my Twin,(hint hint..if it gets here..hint hint) if that means anything,i dunno. I'm wanting a 2 speed but not 4WS. |
| | #3 |
| bendforthebone Join Date: Feb 2004 Location: Jamul
| I am using an inverted stampede tranny. |
| | #4 |
| Colt Python/SR9c ![]() Join Date: Feb 2004 Location: out in the shop, reloading ammo!
| i use both a Maxx tranny and a stampede tranny. my next crawler will use a Maxx tranny. if you use a Maxx, you will want to lock it in 1st gear anyway to eliminate the slop( much nicer |
| | #5 | |
| Newbie Join Date: Jul 2004 Location: Marlton, NJ
| | #6 |
| as soon as you take it apart, you will see where the slop is in between both big gears. you will see the shifter/slide arm to where it shifts gears. then you will see where the one gear has notches to slide into the other. just glue those together. i just used super glue on mine and its been holding for awhile now |
| | #7 |
| Stampede Tranny is the way to go!! |
| | #8 | |
| | #9 |
| Quarry Creeper Join Date: Jan 2004 Location: CSU, CO
| I made an AL piece that fit inside the engage area on the drive gears that reduced slop. So instead of 180 degrees of slop there is about 2 degrees. I have tested it but not in a complete truck “mine is still being built” so I don’t know how long term ware will workout. If you just blip the throttle until it engages it does so smoothly. |
| | #10 | |
![]() Thank you. | |
| | #11 |
| No real pictures since I don’t have a digital camera. But here is the thread with more information <Click. |
| | #12 |
| Rock Crawler Join Date: Jan 2004 Location: Santa Cruz, CA
| for small crawler i would say a losi xxx tranny or a stealth tranny. for big scale go with emaxx tranny. the danm this is so easy to mount thats the main reason i like it. |
| Thread Tools | |
| Display Modes | |
