06-12-2008, 08:26 PM | #1 |
Newbie Join Date: Jun 2008 Location: Lapeer
| Clod steering problem
Hi, out there. I'm the new guy on here so go ahead and give it to me. But, can any one help me with my steering problem. I have a clod and i want to have my four wheel steering work. I bought the integy servo trays, and i have a Y-connector I can't get the rear steer to trun the other way. It turns the same way as the front. Need help |
06-12-2008, 09:09 PM | #2 |
RCC Addict Join Date: Apr 2005 Location: Eden Prairie, MN
| You need a reversable y-splitter for it. I used to have a nice Futaba one that had a 'gain-like' knob to help center the rear steering. |
06-12-2008, 09:24 PM | #3 |
got room to roll your servo over? mean just flip it opposite of where you have it, horn is closest to your wheel as an example then flip it so horn is closer to the tranny. reversible connector? i thought it was the signal wire that told it where to go and the others where just power to it. |
06-13-2008, 09:51 AM | #4 |
Rock Crawler Join Date: May 2007 Location: lacey
rolling servo over wont do squat a reversing Y has a circuit built into it that changes the signal to one of the servos. They usually have an adjustment pot on them so you can trim the reversed servo. |
06-15-2008, 09:02 AM | #5 |
Newbie Join Date: Dec 2006 Location: England
you can do it without a reversing Y lead. Front servo is mounted so that the servo horn "mounting post" is pointing forwards. The rear servo has the servo horn "mounting post" pointing at the ground. That make sense? |
06-15-2008, 09:40 AM | #6 |
One servo horn faces up, the other faces down.
