| | #1 |
| Colt Python/SR9c ![]() Join Date: Feb 2004 Location: out in the shop, reloading ammo!
| well after reading another post on here about 4 links and setting them up, i had finally gotten to that step on my project. got the 4 link setup with my chassis links have about 1/2" seperation and my axle links are about 3/4" seperation. i wanted to do a double triangulated, but my chassis wouldn't allow it anyway, the axle seems to do great. it doesn't move and the pinion is always pointing at the t-case, but it seems to have alot of axle steer( which i hate) what is the actual cause of axle steer? anyone know what i could do to change it? my last double triangulated setup didn't have any,but like i said, i really don't have the room to do it now. do i just need more seperation at the chassis? i don't feel like going over to Pirate and searching through nonsense for hours thanks for the input ohh btw-, yeah dave i know its not a real truck but i hate fawkin axle steer |
| Sponsored Links | |
| | #2 |
| PapaGriz Yo ![]() Join Date: Apr 2004 Location: Planning
| Far as I know the only cure for axle steer is double triangulation. I may be wrong but I have never heard of anything else, horizontal links help but only a little. You could take out some travel I agree with ya, even though it is a toy it is better to make things werk right. |
| | #3 | |
i guess i'll run it how im setting it up now to see how it does. if it isnt what i want, i guess i can always cut it up some more | |
| | #4 |
| TEAM MODERATOR ![]() Join Date: May 2004 Location: Tennessee
| Longer flater links will eliminate axle steer. I don't know from experience,it's just what I've always read. |
| | #5 |
| Pebble Pounder ![]() Join Date: Jul 2004 Location: Quakertown PA
| Dont think I've heard of axle steer before. I assume it is the vertical centerline of the droop side moving back when it flexes. There isnt any way to completely eliminate this, is there? |
| | #6 |
| well i said fawk it!! i cut the chassis up to be able to do a double triangulated setup. it acts much nicer now smokingun- axle steer is when a tires drops down, it wants to move forward also. yes you can eliminate it |
| | #7 |
| Well thats interesting Twisted. How could a tire move forward as it drops? Your links cant stretch. Is there lateral movement of the axle? Maybe I'm missing something. Maybe I'll run into it when I get a rig to that point. |
| | #8 | ||
![]() Currently my setup is like the one with the blue uppers and my pinion is moving around more than I can handle. Would changing my uppers, to mount like the red uppers, make the pinion stay with the tranny? Triangulation wise,they will stay the same(as pictured) Quote:
| | #9 | ||
| | #10 | ||
| | #11 |
| Okay raptorman, I was confusing myself by focusing on the front axle. You're right, the rear can move forward. |
| | #12 |
| yes steve, if you mount them closer the angle will stay the same. mine were pretty close together and the axle stayed at the pinion no matter what. also, my links were the same length almost. as for rearsteer smokin- stand on a skateboard with the " trucks" as loose as possible and then lean left and right and watch the wheels. the front move back and the rear move forward. also found that where i had my lower links mounted( close to the outside of the chassis) was the blame of it. as the chassis tilted up,it would bring the link up with it. causing it to bring the axle in forward also. now that i went double triangulated, my lowers are in the center of the chassis as where the links hardly move.plus having them in the center and my uppers mounted to the outside of the chassis now,it kind of eliminates both of them at the same time |
| | #13 |
| Newbie Join Date: Jun 2004 Location: Calgary, Alberta, Canada
| Hmm I had a case of axle steer on one of my 4 link designs, and the only thing that i found was causing it was a locked diff. After the wheel up in the air comes down the other one on the same axle want to turn and thus it incorperates any play in the ball ends or any link movement it can. When it uses the play at the ball joint it can move one side of the axle forward more so your axle ends up crooked compared to the other one. If your ball ends and everything are tight and there is no play then it may just be the angle at which your links go to the chassis. |
| Thread Tools | |
| Display Modes | |
