Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: Servo bolts instead of screws?
Old 08-10-2004, 12:10 PM   #1
Default Servo bolts instead of screws?
I stripped all four of the steering servo mount screws off my e-maxx. Can I just drill holes in the chassis and replace the screws with nuts and bolts to hold them in?
I guess the high torque servo stripped them out.
Thanks
crawlmaxx is offline   Reply With Quote
Old 08-10-2004, 06:10 PM   #2
Default Re: Servo bolts instead of screws?
sure. And maybe add some shaped aluminum to back it up. Or washers at least, as big as will fit to spread the load.
Cutter is offline   Reply With Quote
