08-28-2008, 05:10 PM | #41 |
If the gears aren't actually 48p it will make a lot of noise with a 48p pinion. 48p metric is mod 0.6, and I wouldn't doubt if they are labeled as 48p but they forgot the "metric" part.
08-28-2008, 05:12 PM | #42 | |
Rock Crawler Join Date: Jun 2007 Location: Hopewell
| Thanks Rene. Quote:
Thanks for the comments, and yeh, TCS has them - http://www.tcscrawlers.com/Hot-Racin...8-p-17009.html. Looks like they are already out of stock on the black ones though. If you really want black, there are other places if you look but I'm not recommending it. I'm sure Kevin will be getting more in soon. | |
08-28-2008, 05:18 PM | #43 |
Rock Crawler Join Date: Jun 2007 Location: Great Britain
You did a great job on the write up on these. They look really cool on your chassis. I love the looks them but now I have to decide between these Bergs and bullys. Damb I hate having a choice . |
08-28-2008, 05:23 PM | #44 | |
From Nluv's reveiw of the HR axles. Quote:
08-28-2008, 05:26 PM | #45 | |
| The upper link mount is off-centered....a little. Quote:
Gotta to take a break from this thing until hopefully sometime tomorrow, I have other priorities tonight. Stay Tuned. Pics | |
08-28-2008, 05:32 PM | #46 | |
Ok, so all I did was take the 14t pinion off the motor that was mounted to my AX10 transmission and used it on the rear. I then grabbed another 15T pinion (originally purchased to be used for the AX10), and threw it in the other motor. They lined up just like any other motor I've mounted with no recognizable issues. Unless the 48P and 48P metric are so close, I just can't tell. To be honest, I have no idea how to tell the difference just by looking at them. I figured if I was using the wrong type, it wouldn't line up and run. I'll do whatever I can to help solve this though. | |
08-28-2008, 06:53 PM | #47 |
| Thanks to you and Nluv for all the help, i did some shopping at TCS for the parts i didn't have, all i have to do now is figure out the motors i will use on this pup, time to call on JRH again |
08-28-2008, 07:06 PM | #48 |
08-28-2008, 07:19 PM | #49 |
08-28-2008, 07:20 PM | #50 |
08-28-2008, 07:23 PM | #51 |
08-28-2008, 07:28 PM | #52 |
08-29-2008, 07:09 AM | #53 |
What pitch are these gears? |
08-30-2008, 10:46 AM | #54 | |
I can definitely say that the Berg pinion and the Hot-Racing pinion are not swappable. Last night when I was taking the 45T from the HR axles to put in my Berg rig I first tried putting the Berg pinioned motor in the Hot-Racing axles and vice-versa. They both would spin but not smoothly and made a horrible racket. The Berg pinion seems to be bigger in the sense that the gaps between the teeth are wider. I don't know, but what's important is, they are different!! So, with that, I now have two 55T motors, with at 14T up front and a 15T in the rear. However, I had to take the electronics from it to build my backup electronic system for Nationals. So right now, I have to rewire the motors in order to use the Deans plugs for my electrical system, and I'm too lazy and am going to test some changes to my Berg. After all, I think that rig should be what's most important right now, at least until after next weekend. Stay tuned as I hope to get this setup on the rocks, if not before Moab, then shortly after. | |
08-30-2008, 11:00 AM | #55 |
Rubicon this has been a very informative thread. I look forward to your next postings.
08-30-2008, 01:34 PM | #56 |
RCC Addict Join Date: May 2006 Location: China Grove, NC
Hey there I have some new HR axles on my bench. The first gear is 48 pitch. But the first gear will not work with a Berg 2nd gear. To get 48 pitch in the Berg you must change the first gear, the scecond gear and a bearing. The shaft on the 2nd gear on HR is smaller, just on one side. I will see how tough these are, I am putting the HR gears into my Super build in Berg axles. I am doing this because I can get a greater gear reduction with 48 pitch vs 48 metric. I had the noise too initially, when you assemble the gear case you have to make sure that the diff gear seats all the way into the bearing on the long axle side. The slap on some AE black they are quiet. |
08-30-2008, 03:58 PM | #57 | |
08-30-2008, 04:02 PM | #58 |
| Thanks. Just trying to learn and help others while I'm at it. I'm trying to talk myself into messing with this rig some more today and rewire my motors, make the new links, etc. But I just got home from some more Berg testing and can't get motivated, it was hot out there.
08-30-2008, 06:56 PM | #59 |
Well i went a different route on the chassis, ordered a MFM, i'll post up next weekend when i get all my stuff in, and will start bothering and pestering you guys for info.
08-30-2008, 08:36 PM | #60 |
| No problem, anytime you have a question ask away and I'll do my best to help. I'm looking forward to your build with that chassis. I like seeing all of the different kinds of setups people choose.
