08-13-2005, 10:08 PM | #21 |
Rock Stacker Join Date: May 2005 Location: dfw
never mind it looks like i put my front shock mounts too high, if i lower them a little i think the front mount on the body will slide in.
08-13-2005, 10:35 PM | #22 |
Rock Stacker Join Date: Aug 2005 Location: olyWA
Hmmm I'm gonna have to try some of these mods tomorrow after work Thanks for all the tips! Also: Does turning the tires around or cutting them have a good effect on climbing? Which is better? |
08-14-2005, 08:51 AM | #23 | |
Pebble Pounder Join Date: Aug 2005 Location: VT Burlinton
STu | |
08-14-2005, 12:14 PM | #24 |
Newbie Join Date: Aug 2005 Location: Whitmore
Has anyone removed the drag link? I want to take the steering motor out to "shave" it. But I can't get the steering motor out, with out removing the drag link. I don't want to make new drag link.. Any ideas?
08-15-2005, 05:05 PM | #25 |
Newbie Join Date: Aug 2005 Location: Fred-neck
this is how i shaved it using a licenc....i mean "scrap aluminum" the battery is mounted in the middle with double sided tape (the electrical tape in the pics was for mock-up) on its thin side. basicly the battery is flush with the upper rails. the electronics are lay flat on the rear. its a good 2 inches higher |
08-15-2005, 05:31 PM | #26 |
Quarry Creeper Join Date: Jul 2005 Location: north central IL
I tried the cutting of the bumpstops on the rear axle and it does give you a little bit more movement. Keep the mods coming!! Matt |
08-16-2005, 07:27 PM | #27 |
Rock Stacker Join Date: Aug 2004 Location: SAN DIEGO
08-22-2005, 08:56 PM | #28 | |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
| upper shock mount relocation
Did this mod today. It is well worth doing. Thank for the ideal Quote:
08-22-2005, 09:12 PM | #29 |
Pebble Pounder Join Date: Aug 2005 Location: Gilbert
Do you loose any ride height with putting the shock mounts in? I guess it's not a big deal seeing as I've never gotten hung up on the body, just the massive diffs!!
08-23-2005, 03:19 AM | #30 | |
Newbie Join Date: Aug 2005 Location: OC
So far I've painted it: Shaved it: Made a skid for it: I also remounted the battery, computers, and power switch. In addition I inboarded the springs to obtain more articulation. | |
08-23-2005, 05:39 PM | #31 | |
| different springs Quote:
I have some savage spings on mine. They are to soft to resore height lost by the mod, but will place stiffer ones when they come in. Hopefully this will maintain increased articulation and stock ride height. PS: I'am using washers that fit over shock body as spring retainers. | |
08-23-2005, 08:26 PM | #32 |
I have restored the stock ride height by placing the stock springs inside the savage springs. No loss of articulation. Combo springs seemed to be as stiff as the stocks in stock shock location.
09-08-2005, 02:36 PM | #33 |
I like this thread:-P i just found a good shot of how i cut my tires and thought i would post it: Stu |
09-08-2005, 09:28 PM | #34 |
Is there any right way to cut your tires? Is there a pattern that will give you max grip? I like the look of cut tires a lot more also, more agressive.
09-09-2005, 09:35 AM | #35 |
RCC Addict Join Date: Aug 2005 Location: Akron
- cut tires - thru-holed the rims for air movement - Tummy tuck with relocated electronics and battery - Steel bumper - Inboarded rear shocks - Paint scheme - LED headlights http://www.rcpics.net/view_single.php?medid=64511 |
09-09-2005, 10:58 PM | #36 |
Rock Stacker Join Date: Aug 2005 Location: Mesa
dang.. NICE bumper!!!! That thing just needs a 1/6 scale winch now. |
