08-10-2005, 11:08 PM | #1 |
RCC Addict Join Date: Jul 2005 Location: Provo
| Various Chassis Modifications to Start With
What have you done to improve your rock crawler? so far i have taken off the skidplates and have turned the tires backwards what about you
08-11-2005, 05:46 AM | #2 |
Newbie Join Date: Aug 2005 Location: Fred-neck
gutted the rear of the body,removed the windshield,painted the cage. turned just the front tires around,removed the "skid plates" ,and generaly beat the crap out of it till the body was nice and scratched up
08-11-2005, 12:14 PM | #3 |
soon to come to mine are aluminum skidplates and possibly even a winch we'll see
08-12-2005, 05:17 AM | #4 | |
Just a thin sheet stuck to the difs and wrapped up the front and back. no loss is clearance and aproach angle and it keeps from gougeing/getting stock on the axles | |
08-12-2005, 07:21 PM | #5 |
Pebble Pounder Join Date: Aug 2005 Location: VT Burlinton
i have -cut tires front and rear -removed useless skid plate -inboarded upper shock mounts, huge flex increase -drilled small holes in back of rim to let air escapse quicker -painted body -tow straps(not pictured) just adds to realism mine VS stock: Stu |
08-12-2005, 07:52 PM | #6 |
Newbie Join Date: Jan 2005
WOW man that looks awesome nice paint job and it get's awesome flex as well.
08-12-2005, 08:08 PM | #7 | |
stu | |
08-12-2005, 10:34 PM | #8 |
Newbie Join Date: Jun 2005 Location: key largo fl
these crawler with minor mods makes them flexx gust as good as our 1000 ones |
08-13-2005, 12:01 AM | #9 | |
Newbie Join Date: Aug 2005 Location: Provo
08-13-2005, 08:01 AM | #10 |
08-13-2005, 09:50 AM | #11 |
sweet, thanks man
08-13-2005, 10:19 AM | #12 |
figured a way to get a LOT more flex if you look where the "control arm" pivot is on the top of the axle there is little plasic tabs on the top of the axle under the cross bar of the arm. if you sneak in there with a dremel you can take them out and it adds like 10* of flex either direction.
08-13-2005, 02:49 PM | #13 | |
the flex comes from the center piviot on the axle housing. From what i can see on mine, the only real thing stoping the flex is the shocks/springs. I am at the point on my front end where when one shock is almost completely open, the other still has about 1/2in of compression. I am going to go in with my Dremel tonight and take some materal out to see if i can get all the flex. updates later Stu | |
08-13-2005, 03:50 PM | #14 | |
AT THE AXLE !! the top piviot right on the top of the axle on the rear has little tabs inside the pivot. on the axle it self not the blue control arm or the body you take those out the axle will articulate to a greater angle. The front doesnt have these. but the front can get more compression from notching the blue control arms where it comes in contact with the tub. on mine i also cut a half inch off the bottom of the "shock tube" to get more compression and put fishing line "limiting straps" to keep the shocks from pulling apart. I just got threw shaving 2 inches off the bottom and making a new belly pan out of a scrap piece of aluminum sheet the battery is now on its edge and the electronics are layed flat in the rear. I need to fix my belt problem next. My goal is to buy as little of new parts as nessisary and see what i can get this to do | |
08-13-2005, 03:58 PM | #15 |
08-13-2005, 05:52 PM | #16 | |
Stu | |
08-13-2005, 05:55 PM | #17 | |
Stu | |
08-13-2005, 07:08 PM | #18 |
camera died, funny being as being a photographer is my job. my others are at work, i might have to bring one home on mondaay |
08-13-2005, 07:36 PM | #19 |
Rock Stacker Join Date: May 2005 Location: dfw
o.k. so i moved my shock mounts in like in the pics , but how do you make the front of the body lock in since the mounts are now where the body should lock in?
08-13-2005, 09:05 PM | #20 | |
Stu | |
