10-09-2008, 07:44 AM | #1 |
Pebble Pounder Join Date: Aug 2008 Location: frederock,maryland
| Other wheel axle applications for TLT axles
I was told that wheel axle shafts from other tamiya vehicles will fit the TLT axles.Which vehicles are these?This is what I need http://www3.towerhobbies.com/cgi-bin...&I=LXGG15&P=OW |
10-09-2008, 08:56 AM | #2 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
Those are what you want if you want to widen your TLT axles by a less-than-ridiculous amount. They are long enough to allow you to run 2 hexes instead of one, for a width increase of about 1/4" - 5/8". The problem is that the drive cups are a bit longer on the Blackfoot stub shafts, you need to grind them back a bit to shorten them, then re-grind the bevel inside to match. I did a drawing last year about this let me see if I can find it for you. Where are you Crawling in the Frederick area? |
10-09-2008, 09:27 AM | #3 |
I can't find the drawing - I'm guessing it was in my laptop that crapped on me a couple months back. Anyway, shortening the drive cups is not absolutely neccesary, but it will give you more steering range. Or if you can swing it - a set of MIP CVD's will solve a lot of your problems just by installing them (wider, stronger and improved turning radius) |
10-09-2008, 10:09 AM | #4 |
I have the extended hexes on my axles |
10-09-2008, 11:41 AM | #5 |
So you just need longer threads? The Blackfoot stub shafts should give you that...
10-09-2008, 12:04 PM | #6 |
10-09-2008, 09:52 PM | #7 |
Quarry Creeper Join Date: Nov 2006 Location: Manchester
10-10-2008, 06:43 AM | #8 |
Where are you Crawling in the Frederick area? Sugarloaf mountian mostly thats where we hold the maryland meets and occasional bash sessions on sundays |
10-10-2008, 06:44 AM | #9 |
10-10-2008, 07:22 AM | #10 |
Here you go. They have bothin stock, and give a description of what both are used for. http://www.orcrc.com/crawlmart/upgrades.htm |
10-10-2008, 07:35 AM | #11 |
thanks bro!!!!
