Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: how wide of a wheel track.........
Old 11-01-2008, 08:12 PM   #1
Default how wide of a wheel track.........
what's a good width for a crawler, wide or narrow....i'm bout to order a set of VP dirty harrys for ax-10 axles and i am wondering what off sets to get ........bob
bob1961 is offline   Reply With Quote
Old 11-01-2008, 08:27 PM   #2
Mriswith's Avatar
Personal preferance and axle diff clearance really. If your running a tall tire like Panthers you can get away with a wide off set. If your running a shorter tire like the Losi Claws you might not want wider than stock Axial width.
Wider is better, it will give you better side hill capability, especially with the higher profile from a taller tire. Something to keep in mind, if you run a lot of weight in the wheels, you put more stress on the knuckles the farther a wheel sticks out.
Mriswith is offline   Reply With Quote
Old 11-03-2008, 09:15 AM   #3
thx, i thought i read a post where it was better to have a wider front axle then the back....but i couldn't find it.............bob
Old 11-03-2008, 05:01 PM   #4
Tech Addict
frdtrkguy's Avatar
10 1/2 is as wide as I would want to go on a comp rig. I am at 10 1/4 now with 5.5" tall Rovers. Truck works good at this width.
frdtrkguy is online now   Reply With Quote
Old 11-03-2008, 08:16 PM   #5
thx ..............bob
Old 11-03-2008, 10:31 PM   #6
Gavyn is my BFFL
Nabil's Avatar
the widest ones vp make are the same offset as the stock wheels
Nabil is online now   Reply With Quote
Old 11-04-2008, 10:11 PM   #7
I believe that is the 585 offset for AX-10 width.
RC Shocker is offline   Reply With Quote
