08-28-2005, 09:54 AM | #1 |
Newbie Join Date: Aug 2005 Location: Denver
| Front or Rear springs
I messed up one of my springs, so i'm removing the other one on the same axle. I read that it is better to have trimmed springs then no springs at all. My question is, if I were to only have 2 springs, is it better to have them on the front or rear? Oh and the springs I have are trimmed 4 coils, if that matters. EDIT: Oh and it's the Jeep one if that matters either. Thank in advance, Taylor. Last edited by XJ96PA; 08-28-2005 at 10:03 AM. |
08-28-2005, 10:43 AM | #2 |
Quarry Creeper Join Date: Aug 2005 Location: crescent city
use them up front/you can run the shocks with no springs on rear
08-30-2005, 04:17 PM | #3 |
Newbie Join Date: Jun 2005 Location: Phoenix
I would run them in the rear. I found on my TXT that it works better with a stiffer rear end and a looser front end. This helps the front wheels flex around while keeping the rear end planted. Since it is easy enough to move them around, experiment a little and see what happens. Just my two cents. Dan |
08-30-2005, 04:34 PM | #4 |
RCC Addict Join Date: May 2005 Location: Auburn, WA
I'd run them in the back, it wont want to drive under itself as much.
08-30-2005, 05:09 PM | #5 |
RCC Addict Join Date: Aug 2005 Location: Oceano, CA
put them in the front. with no springs in the front, my Jeep would sit on the front axle... this caused it to sit a little to one side. i don't know what the scorpions are like, but i found that problem on my Jeep.
08-30-2005, 06:47 PM | #6 |
extend center pivots & wire up solid! the body kinda flops but it wheel great!
