Broken pinion gear?? I was out crawling today....and this happened http://i21.photobucket.com/albums/b2...er/kids002.jpg What is a good replacement for this?? One that is steel? The one that broke is a 10T, and all my local hobby shop has are 12T...how much of a difference will 2 teeth make? Did have a good time before it broke.... http://i21.photobucket.com/albums/b2...1214081057.jpg |
the 12t will be fine you wont notice a difference, but a little more wheel speed. |
Found an 11t at Tower....I assume it needs to be 48 pitch? http://www3.towerhobbies.com/cgi-bin...?&I=LXJHU0&P=7 Would this work? http://www3.towerhobbies.com/cgi-bin...?&I=LXBGE6&P=7 |
Nope none of those will work. This will though... http://cgi.ebay.com/Axial-Ax10-LONG-...3A1%7C294%3A50 |
Thanks...ordered it tonight |
FYI...the Axial pinion gear does not fit without cutting. the hole is not deep enough to clear the spur gear. |
