01-11-2009, 02:31 AM | #1 |
Rock Crawler Join Date: Dec 2005 Location: North Vancouver
| Why no r&P gearing options from vendors?
I just saw a post from a new person to this forum and I have always wondered the same thing but never asked. With all the aftermarket things being built I don't understand why something so important is missing from the vendors. I'd love to be enlightened. Why are there no lower ring and pinion gear sets available? One of the biggest issues with shafties is torque twist. This seems to be the missing piece to minimize torque twist combined with better link geometry. Look at the new losi crawler, lots of gearing with worm gear to reduce/eliminate twist...no reason why there can't be lots of gearing with a r&p. I'm from 1:1 crawling. We can change motors to have more torque hp and higher rpms, change transfercase gearing, and then gearing in the axles. With rc crawlers you can do the first two but not the last. Imagine 1:1's only being able to run one axle ratio....we're missing a huge piece of the puzzle. And stuck on a brutal ratio too. Ax-10 ratio 2.92 Where are my new 5.29's for my new 5.5" HB Rovers? There's always talk about what gearing the tranny has but nobody talks about what the gearing is in the diffs which is just as important if not more. The only explanation I can come up with is that if you don't come from 1:1 and have been involved with other rc's all the gearing comes from the tranny which gets sent directly to the tires in most other cases so there isn't any thought given to axle gearing Last edited by miller; 01-11-2009 at 02:55 AM. |
01-11-2009, 02:44 AM | #2 |
Rock Crawler Join Date: Sep 2004 Location: eureka
i agree with this idea . it would be awesome to have different ring and pinion ratios available. i know that there is a low gear set available for txt axles . i dont know how they could make a lower gear set for axial axles without changing the axle case(cheap plastic anyways so thats not a huge problem) i think i would be worried about the strength of lower gears though. |
01-11-2009, 04:06 AM | #3 |
Just because I can't sleep I did some reading using stock Ax-10 data and have a better set up that I'd like to try. Stock Ax-10 Internal tranny gears 2.6 Stock pinion (14 tooth) and spur (87 tooth) 6.21 Total tranny ratio = 16.15 ^^^^^ That is the problem, very low sprung weight, so very soft springs on shocks (which are always on a slant decreasing effectiveness) with lots of torque on the chassis = torque twist. And then multiply that by bad link geometry. That's how I see it and I could be very wrong. All that leverage sitting on the chassis then gets pushed to a 2.92 ratio ring and pinion in the diffs for a final stock crawl ratio of 47.2 which I like with my 7t on 3cell. I'd like to try this: Internal tranny gears 2.6 20 tooth pinion 87 spur 4.37 (it'd be nice if they made smaller spur gears too not sure if they do) Total tranny ratio = 11.36 ^^^^^ More torque taken off the chassis and moved into the axles. And have that move down to 4.15 ring and pinion to keep the same final crawl ratio at 47.2....just a transfer of where that torque is happening. It'd be great if a vendor made a bunch of 1:1 common ratios like 4.56, 5.29 etc. This would result in less strain on the tranny outputs, less strain on driveshafts, less strain on r&p, more strain on axle shafts and lockers. And in theory reduce torque twist. It would also increase the strength of your drag brake...I think, thoughts? I'd also be interested in how this would effect run time and the type of motors you could run. Because the final drive ratio is the same do run times stay equal? Or would run times change with the change of where the gearing is happening. Because more gearing is happening at the axle does the motor need less torque? Now I'm tired :-( Last edited by miller; 01-11-2009 at 04:14 AM. |
01-11-2009, 07:35 AM | #4 |
Rock Stacker Join Date: Dec 2005 Location: Socal
Probably because of the lack of a way to adjust the gear mesh.
01-11-2009, 10:30 AM | #5 | |
I wanna be Dave Join Date: May 2006 Location: akron
and unlike 1:1 where gearing in a tranny would be harder to change here it is the easiest thing to change and the diffs are allot more involved, this doesnt mean its the best solution but it is the easy one.. | |
01-11-2009, 10:40 AM | #6 |
Pulling apart a tranny to install new outputs for dig would be no harder. Throwing in a new ring and pinion with a different ratio would be just as easy as putting in a new stainless locker. I don't see how that is overly involved. To make it easier a full new ring and pinion ratio with a spool would make it even more simple. As for gear mesh...that's a non issue I think unless I'm missing something. I could be missing something but isn't it just as simple as making a different ratio that will fit in the same housing? Should be the same as 1:1 on that end. |
01-11-2009, 10:58 AM | #7 |
Rock Stacker Join Date: Nov 2008 Location: Small Town
The reason that there are no different ratios for the Ring and pinion is cost. It would cost way more to change the ratio by way of the ring and pinion. A new pinion for the motor is only a few bucks, and you dont have to take the axles apart to change your ratio. Changing the ring and pinion ratio would have more benifits as you stated above, but its just not nearly as pratical cost wise. |
01-11-2009, 01:16 PM | #8 |
That's a bad excuse. There's no higher cost for stamping a new ring and pinion with a different ratio and no more inconvenience to putting in the gears. How many people have avoided buying heavy duty ring and pinions, straight axles, or lockers because it was too inconvenient to pull the axles. This is an rc that you can pull apart in 5 minutes on your coffee table. And gearing isn't something you change on a regular basis. |
01-11-2009, 01:32 PM | #9 | |
01-11-2009, 01:55 PM | #10 |
Very interesting thread, i have also wondered why there weren't any different r&p ratios out there, let's hope a vendor gets involved on this topic |
01-11-2009, 02:32 PM | #11 |
Pebble Pounder Join Date: May 2008 Location: Bellevue
May the reason being that the teeth on the R&P will be too small? Just like in Toyota 1:1 world. No one goes below 5.29 due to the fewer number of teeth need on the pinion to acheive that ratio. You lose pinion to ring gear contact, there for making the pinon the weak link. Just a thought |
01-11-2009, 03:15 PM | #12 | |||
And if you had $60 worth of gearing in your ring and pinions (front and rear $30x2) plus a $3 pinion you could potentially be saving money because your stock driveshafts would hold up and your stock output's would hold up. So right there you wouldn't need over $100 in parts that you would have otherwise spent upgrading. That's looking at ax-10 axles. Quote:
I was also hoping Holmes might be able to chip in some ideas about run time and motors. Quote:
I think the real reason is that solid axles are relatively new as is crawling and it's an oversight in the market that comes from tranny gearing being the be all end all in other forms of RC's. (That's speculation because I don't know anything about rc's outside of crawling.) | |||
01-11-2009, 04:28 PM | #13 |
A higher r/p ratio would be ideal. Like you said, so much stress would be relieved from the trans and driveshafts. I would imagine run times would increase somewhat because the trans/motor wouldn't have to work so hard, and torque twist would be greatly reduced. In the long run it would be cheaper. Think about how much money is spent on metal trans gears (so the won't strip), cases (so the new metal gears won't blow it up), and reduction units. Hell, just look at the aftermarket trans selection vs diff selection. Its night and day. Even when you do find a fully aftermarket diff it might have upgraded gears, but its still the stock ratio. I really don't think its a matter of build cost. How much does it cost Axial to pump out a fully built axle? $10 per? How much would it cost them to whip out one with different gearing? $10 per? Maybe $11 or $12? If I could get a better ratio for my Maxx diffs, it would be well worth the $60. I'd buy them the first chance I had... I know someone. I think a phone call is in order here... |
01-11-2009, 04:46 PM | #14 | |
There is an easy solution though...........MOA. HAHAH JK. Just saying that a new R&P ratio is not a project that I expect to work on any time in the near future. | |
01-11-2009, 04:56 PM | #15 |
01-11-2009, 04:58 PM | #16 | |||
If someone has the right tooling,it would be rather simple to make different ratios. In my super,I can choose between a 3.3 ratio or a 4.3 ratio.:-P Quote:
Right now,my Axial based 2.2 truck runs a 19t pinion/87t spur with a 10t puller on 3 cells. It's pretty quick with plenty of bottom end grunt. Wouldn't mind getting a touch higher gear though. My super runs 18/81 pinion and spur with a 3.3 ratio in the axles. Same motor and voltage. Again,wouldn't mind a touch taller gear for the axle. Quote:
It's all very feasible to do. | |||
01-11-2009, 04:59 PM | #17 |
01-11-2009, 05:02 PM | #18 | |
And they can't be that expensive to make otherwise the market wouldn't be filled with HD ring and pinions for relatively cheap prices. What's the difference of offering a heavy duty gear set in a different ratio. You're still incurring the cost of making gears either way aren't you? I think you need a challenging project harley Get on a new gear set for the ax-10. 34 tooth ring gear and 8 tooth pinion boot up the solid works | |
01-11-2009, 05:06 PM | #19 | |||
The main advantage that I see coming from this is minimizing torque twist or eliminating it. You can still do all the gearing changes you like through pinions and spur gears. You guys are the big dogs...where's that bender dood. Get him to have axial punch them out. Quote:
Quote: Last edited by miller; 01-11-2009 at 05:41 PM. | |||
01-11-2009, 05:38 PM | #20 |
RCC Addict Join Date: Nov 2005 Location: Utah
Two words: enroute berg |
