01-14-2009, 10:39 AM | #1 |
Newbie Join Date: Jan 2009 Location: newville
| which one
i am a newbie looking at two different crawlers the losi 1.9 crawler and the AX 10 both in rtr models which one is the best starter and gives you best quality for the money. im not looking to buy one that i will have to spend alot on to bring it up to specs either . so which is better rtr crawler
01-14-2009, 10:54 AM | #2 |
Rock Stacker Join Date: Jul 2008 Location: lovelock
axial is way better!
01-14-2009, 01:53 PM | #3 |
Those little 1.9 Losi crawlers are cool, I want one, but I wouldn't give up my Ax10 for it...
01-14-2009, 08:04 PM | #4 |
Rock Crawler Join Date: Jan 2007 Location: San Clemente, CA.
Axial the bar none choice
01-14-2009, 08:29 PM | #5 |
so if i go with the ax 10 rtr can i get just any battery that is a 7.2 and meets the specs and is there anything else that are minor cheap mods to help it
01-14-2009, 09:00 PM | #6 |
Rock Stacker Join Date: Dec 2008 Location: Kalamazoo, MI
It depends, the axial RTR is geared more towards a basher kinda then a crawler. The Losi MRC doesn't need much in the way of mods to be very capable. In order to really make the axial RTR a true crawler you need at least change the gearing or go with a 55t motor. So long story short the MRC is more "Crawler" out of the box and the Axial rtr is more "rock racer" out of the box. So whatever style fits you best! |
01-15-2009, 05:59 AM | #7 |
doesnt the rtr ax 10 come with the lower gearing or isnt that low enough
01-15-2009, 03:16 PM | #8 |
bump
01-15-2009, 09:43 PM | #9 |
RCC Addict Join Date: Nov 2008 Location: Frederick
| my buddy has the RTR, & yes the lower gear will do the job. You will need to up grade the links after a wihle, but the stock ones will hold up for a good time. You will need to do some free up grades such as drill holes in the rim's, & cut the foam's. Plus put stick on weights on the rim's, & look into lowering the ride height by putting fuel tube in the shock bodies. Just shearch cheap up grades in the Ax-10 forum. A good set of tire's will be one of the best things you can do. Good luck. |
01-15-2009, 10:47 PM | #10 |
Newbie Join Date: Jun 2008 Location: Winnemucca
me personally I would buy used and not new it will end up costing you a lot of money to make a stock axial work and perform. new isnt always better |
01-21-2009, 12:12 PM | #11 |
Newbie Join Date: Dec 2008 Location: Santa Margarita
Hello - The losi crawler that is coming out has front and rear dig... is that legal in comps? It has so many awesome sounding points to it. I currently have the scorpion and love it, but don't have much money into it. Just starting out, but have been crawling for about 5 months now. Maria
01-25-2009, 05:42 PM | #12 |
Pebble Pounder Join Date: Jun 2007 Location: Harrisburg
It only depends if size matters. |
01-25-2009, 08:54 PM | #13 | |
Pebble Pounder Join Date: May 2008 Location: Bellevue
The original poster is refering to the Losi MRC 1:18 not the new 1:10 losi that is coming out in a month or two. and Yes front and rear dig is legal in comps. MOA's have been using it for a while, us shafties are finally starting to get the option. | |
