Thread: r2d disconect help
Old 01-18-2009, 06:17 PM   #1
Default r2d disconect help
i just got my dig going and when i lock the back tires the front just pulls the links aparts. What could i do to stop pulling the links out? There is another problem when i lock the rears the front tires dont really slide they just want to pull the car and break the links
4x4wheelier is offline   Reply With Quote
Old 01-18-2009, 06:20 PM   #2
Are the ends of your links stripped? I've had mine bound pretty good and never pulled a link apart.
dirtyal is offline   Reply With Quote
Old 01-18-2009, 06:25 PM   #3
On the lookout for Rocks
constantmotion's Avatar
Your link suck...replace the rod ends. They are more than likely stripped out too big.
constantmotion is offline   Reply With Quote
Old 01-18-2009, 06:41 PM   #4
Default dig
well then what could i do to prevent it from pulling the front tires away from the front?
Old 01-18-2009, 07:46 PM   #5
That is what it's supposed to do when the dig is engaged. Replace your rod ends so the front doesn't rip apart.
I reread your first post and you mentioned that when the dig is engaged the front wheels don't have enough power to break them loose? Battery charged? any more details on you rig?
cutlaSS is offline   Reply With Quote
Old 01-18-2009, 08:28 PM   #6
should i have to adjust my steering so its negitive or positive or sould i just leave it in nutral?
