01-19-2009, 04:30 PM | #1 |
I wanna be Dave Join Date: Oct 2008 Location: I miss Rowdy
| How to make a rig more stable on STEEP climbs
Hey guys, I've finished my build and am having a bit of a problem, On Steep climbs my rig wants to tip backwards easily. I'm running a DNA slingshot w/Dig Tekin FXR motor and ESC HPI Rock Grabbers, Belly height is at 3" from the extra height of the tires. Was at 2 5/8 with my Claws. Didnt really seem to do any better with the other tires though. Any thoughts?? |
01-19-2009, 04:46 PM | #2 |
Rock Crawler Join Date: Jul 2007 Location: Rectalville
Got any pics of your rig? What shocks are you running? Any weight in the rims? Where is your batt mounted, etc. How steep of a climb are we talking here? if it's really, REALLY steep, (like 70 deg. or more) then you might consider getting a dig unit and just trying to use the front dig to pull you up. That will stop the whole "stand straight up then go over backwards" thing right there. |
01-19-2009, 04:47 PM | #3 |
Newbie Join Date: Feb 2007 Location: Gainesville
Are you running any weights in your front tires? A few more details like battery placement would be helpful.
01-19-2009, 05:40 PM | #4 |
Ok, I'm running Losi .6 shocks, Stiff Green springs in the rear, 50wt shock oil, Orange soft springs up front 50wt oil. Front axle mount battery tray, 2 cell 2200mah Lipo MSD Aluminum wheels with 1 full wrap of tape weights plus about 4 extra ounces on each front wheel, thin wrap of tape weights on the rears. I'll try to get some pics up later tonight. |
01-19-2009, 07:41 PM | #5 |
Does it cant to the right or left as it tries to climb or just flip over straight backwards? I have been fighting the same thing since I put on the HB rovers. My belly height jumped to 3.25 Two things should help. Lower the overall height, and put stiffer foam in the rear tires. The foam makes a big difference. |
