Thread: B44 FT front shocks ??
Old 01-24-2009, 02:13 AM   #1
Default B44 FT front shocks ??
Anyone here with a B44 know what the compresed and uncompressed lenghts are from eye to eye ? And the spring id ? I did some searching but didn`t come up with any real info . Thanks .
4XADICT is offline   Reply With Quote
Old 01-24-2009, 08:43 AM   #2
in not sure on the b44 shocks, but the Jammin XC-R1 FTE shocks are very similar i think.
their front shocks are approximatley 117 mm eye to eye and close to 1/2 in diameter. most these buggy shocks are very close to size so id suspect the B44s being close to that size.
Timmahh is offline   Reply With Quote
Old 01-24-2009, 11:39 AM   #3
I assume you ment the 1/8 jammin buggy, the X1-CR , if so they are too big . I`m looking at the 1/10 buggy and truck shocks trying to find a replacement for my revo shocks on my slingshot but with a bit more travel and smaller dia .I`ve looked at the losi .6 and .9 shocks but want to look into any options if I`m going to drop nearly $100 on shocks . I was looking at the b44`s because if I understand correctly they have around .800 travel which is about what I`m looking for just want to make sure they aren`t too long for mounting .
Old 01-24-2009, 03:51 PM   #4
If memory serves me right, the front shocks on a 2WD B4 are .71 & if you unscrew the lower ballend it will extend it to .82 & the stock shocks on a B44 are .82. I THINK that the shafts are the only differance in the .71 & the .82 the bodys are the same.
Speedracer19 is offline   Reply With Quote
Old 01-24-2009, 08:29 PM   #5
Wat about Bandit or rusty front shocks I believe they are 90mm
Snowbeaverking is offline   Reply With Quote
