01-27-2009, 06:45 PM | #1 |
Pebble Pounder Join Date: Dec 2007 Location: Dothan
| rear wheels wobble.
i was out running my crawler today and noticed that the back wheels wobbled when you hold the truck off the ground. both wheels wobble the same and this happens when it is running along the ground too. what can be done to correct this? |
01-27-2009, 07:09 PM | #2 |
Quarry Creeper Join Date: Dec 2008 Location: Punta Gorda, Flo-rida
with the wheels off do the drive shafts wobble, if not then it could just be the way your tires are mounted mine constantly wobble and if i switch tires it may wobble more or not at all, as long as its not a big wobble your fine.
01-27-2009, 07:09 PM | #3 |
Is the wheel wobbling, or just the tire?
01-27-2009, 08:33 PM | #4 |
Quarry Creeper Join Date: Apr 2008 Location: The BoomBoom room
Did your rig fall from a good height lately? Mine dropped off about 5 feet or so right on the right rear wheel.Now it has a wobble. I haven't torn it down yet but I think one of my RCP straight axle shafts have a slight tweak in it now:-(
01-27-2009, 09:54 PM | #5 |
Quarry Creeper Join Date: Jul 2007 Location: Holland,OH
Both me rear wheels got a little wobble But, that's because my son liked to get it out and push it around while I was at work He thought of it as a real cool TONKA.
01-28-2009, 04:36 PM | #6 |
Rock Stacker Join Date: Nov 2007 Location: KamLOOPs, B.C., Canada
Check your shafts, mine fell, or should I say, tumbled down a decent sized hill after climbing it and bent BOTH rear shafts, therefore, creating a wobble similar to what you speak. If your front "tires" don't wobble, then swap them to the rear and see if the wobbling persists, ifso, then you most likely have bent shafts. If not, then it's your tires. HTH
