Thread: My scorp on moabs and my extended jeep.
Old 09-15-2005, 09:30 AM   #1
Default My scorp on moabs and my extended jeep.
These are my 2 1:18's. The scorp is orange and silver, reversed rear axle extended 1" front and rear with inboard upper shock mounts. HPI 5 spoke mesh wheels with moabs.
The jeep is flat black with a red cage and link arms with black out rims. Extended 1/2" front and rear. Inboard upper shock mounts front and rear.
Soon to come, tummy tuck on both, already have the batt's mounted under the hood of each, just need to get material to make the skids and do the cutting.
034x4 is offline   Reply With Quote
Old 09-16-2005, 10:33 PM   #2
STS
lookin good.
STS is offline   Reply With Quote
Old 09-16-2005, 10:35 PM   #3
bad arse red X's, the pics look good.
Trike Kid is offline   Reply With Quote
Old 09-17-2005, 01:08 AM   #4
Pics work fine for me man, they are linked from photobucket.
Here's some wheel shots i took today of the scorp. The jeep already quit steering and the rear axle won't go in reverse anymore, got a replacement coming from nylint though.
Old 09-17-2005, 01:15 PM   #5
looks good. my rear axel won't go into reverse either... I think I fried the electronics. Do you know what caused yours to not work? I'm gonna get a second jeep and use it for parts and 4 wheel steering.
robmurray12 is offline   Reply With Quote
Old 09-17-2005, 01:35 PM   #6
I think the board is fried, because when it stopped steering (it will turn 1/3 direction one way, then will only turn back straight) it stopped going into reverse in the rear axle.
Call customer service they are replacing mine for free.
Old 09-19-2005, 09:35 AM   #7
Finally did the tummy tuck today, still need some metal to make a skid but i got all the cutting out of the way. Gave me a whole lot more clearance. Here's some pics of it in action, and yes it drove into and out of every picture.
No foams!
Old 09-19-2005, 11:10 AM   #8
youll get a little more clearance under the control arms if you flip them - theyll be more level
cincinnati is offline   Reply With Quote
Old 09-21-2005, 08:59 AM   #9
Show some pics on how you got the MOABS and WHEELS to attach to the Nylint axles.
PLEASE
Clark
SupermanWV is offline   Reply With Quote
Old 09-21-2005, 09:51 AM   #10
Hey killer looking scorp with the 2.2 moabs. I have a buddy who recently got a set of them and did the wheel conversion but when he went out to crawl the scorp didnt have enough power to go with the 2.2s one it. I was wondering what battery pack you are using? the stock one? Thanks.
Stump is offline   Reply With Quote
Old 09-21-2005, 10:42 PM   #11
Yup stock batt pack and everything, is he in low gear? Make sure of that, because in low mine has no problem climbing over undercuts.
Here you can see i have the HPI wheel, the supplied large adapter, supplied washer, and the nylint screw. I took a 1/4" allen wrench and heated it up with a propane torch and pushed it all the way though the adapter, creating a 1/4" drive to fit the 1/4" drive hex on the axles. Then i just bolt them up. I did narrow the inside of the wheel so there would be no rubbing during turning.
Old 09-21-2005, 10:53 PM   #12
Here's a newer pic of it, cut off the front headlight assembly, kept hitting the top of my steering cover on the axle, the cut springs and re-located shock mounts didn't help.
Old 09-22-2005, 12:33 PM   #13
Another quick ?? for ya how long of run time do you get with the stock battery and moabs?
Old 09-22-2005, 12:48 PM   #14
probably around 25-30 minutes, only drove it once before the moabs so i dunno what to compare it to lol.
Old 09-22-2005, 01:09 PM   #15
so basically these things are like clod's,keep the axles and throw the rest away?
chafey is offline   Reply With Quote
Old 09-22-2005, 04:52 PM   #16
So far my 2 cell Lipo has lasted around an hour and a half(and still going) with 2.2 ground hawgs!
NaturalBornCrawler is offline   Reply With Quote
Old 09-23-2005, 11:00 AM   #17
I haven't thrown anything away...All i've done is modify the chassis and suspensin, haven't replaced anything besides wheels/tires.
