09-16-2005, 03:32 PM | #21 |
Rock Crawler Join Date: Nov 2004 Location: Roseville
There is no droop. The axle just rotates on the center shaft. It could spin 360 degrees until I limited it by putting shocks on.
09-16-2005, 03:46 PM | #22 |
Moderator Join Date: Jan 2004 Location: chicago
both shocks are fully extended at ride height.
09-16-2005, 04:51 PM | #23 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
what did you build the main parts from? also, the backbone an arrow? looks good |
09-16-2005, 04:54 PM | #24 |
thanks . the backbone is a carbon arrow and the other pieces were machined from aluminum then painted.
09-16-2005, 08:53 PM | #25 |
Newbie Join Date: Aug 2005 Location: PHOENIX
Sweet Rig Indeed. No Problem's With The Low Gear's Yet Stripping Out????? |
09-17-2005, 12:17 AM | #26 |
No gears stripped but I did here alot of clicking from the rear axle with the 2.2s.
09-28-2005, 06:29 PM | #27 |
Pebble Pounder Join Date: May 2005 Location: raleigh
dude that is sooooo freckin sweet sry for posing on an older thread but i just had to im doin the same thing with one of my nylints but i did it alittle easier and the 2.2's work fine for me but i have axles in the right place and everything and im still using stock electronics
09-29-2005, 05:54 AM | #28 |
Newbie Join Date: Sep 2005 Location: Cary
I will be building my stick based truch this weekend if my ball ends arive, my buddy built his last weekend its so easy
