09-15-2005, 07:26 PM | #1 |
Rock Crawler Join Date: Nov 2004 Location: Roseville
| Stick Nylint
I just finished my nylint stick. well, not really. still needs 2.2 tires and then it will be done. pics will be up in about an hour.
09-15-2005, 07:29 PM | #2 |
RCC Addict Join Date: Dec 2004 Location: Central NY
i cant wait to see this thing. hurry up with those pics
09-15-2005, 07:38 PM | #3 |
Newbie Join Date: Jun 2005 Location: Southwest Va
I just said the other day I wonder how long before somebody does a stick. I cant wait to see it!!
09-15-2005, 08:11 PM | #4 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
yeah i was telling JIA that i was gonna make one, but never got th spare time to do so can't wait to see it |
09-15-2005, 08:25 PM | #5 |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
Why did you even post if you didn't have the pictures? Wouldnt it have been better if you had the pictures when you first posted? |
09-15-2005, 08:45 PM | #6 | |
09-15-2005, 09:18 PM | #7 |
09-15-2005, 09:56 PM | #8 |
RCC Addict Join Date: May 2005 Location: Auburn, WA
Needs 2.2's and a body, good work though.
09-15-2005, 11:07 PM | #9 | |
Working on that right now. | |
09-16-2005, 09:14 AM | #10 |
I wanna be Dave Join Date: Jan 2004
three words: clod axles instead |
09-16-2005, 10:28 AM | #11 |
i would rather have a clod but don't have the money. this project only cost me $50.00 (so far anyways) . i also wanted a small and very agile crawler.
09-16-2005, 10:38 AM | #12 |
good points You can now go on living. |
09-16-2005, 10:42 AM | #13 |
lol.
09-16-2005, 11:14 AM | #14 |
09-16-2005, 02:53 PM | #15 | |
Newbie Join Date: Sep 2005 Location: Mid Ohio
09-16-2005, 02:58 PM | #16 |
Quarry Creeper Join Date: Aug 2005 Location: Redding, True Nor-Cal, look on a map
Remove the windshield (& leave it off), take out the cage and the seats. Then cut a section out of the middle of the body with a band saw and glue it back together. Narrow the cage and reinstall it, then just install one seat. AXEMAN did it with his 1:6 scale nylint and it looks great.
09-16-2005, 03:09 PM | #17 |
Newbie Join Date: Feb 2004 Location: Winston Salem
Call me a dumba$$...but how the he!! does the stick chassis work? I understand the center rod replaces the frame... Does each axle pivot on the center rod? Or is one axle fixed to the rod, and the other is the pivoting one? I figure the rod has to pivot since you only use two shocks, mounted on opposite sides of the rod, but I am not even sure of that... Maybe I need to try to throw something together to test with so I can understand how this thing works.... Obviously it's Friday, after 5:00pm, and my brain is in recovery mode from a long work week...its possible that this is a simple concept, and I just cant see the forest for the trees.... Tim AG4RZ |
09-16-2005, 03:11 PM | #18 |
I hate to say it but, I think I'm going to scrap the whole "2.2 class competitor" thing. With the 2.2s the rear end clicks whenever the tires get caught up a little bit. And there is too much slop in the steering for my taste. I think I'll go back to the original tires and make a smaller main shaft. It will be a truck just to mess around with in my spare time and maybe compete in a nylint class of some sort. That's all. Tyler |
09-16-2005, 03:13 PM | #19 |
Iflyos. You got it right. Each axle pivots on the center shaft. The shocks are there to mainly limit the articulation.
09-16-2005, 03:21 PM | #20 |
Tyler...so would I be correct in assuming that in order to work well, you need to have the shocks at half compression when the vehicle is at ride height? So you can have some droop? As I see it, if the axle pivots on the "spine" it could spin 360 unless you limit it with tabs or something, correct?? |
