09-16-2005, 12:49 PM | #1 |
Newbie Join Date: Aug 2005 Location: OC
| Nylint Cust. Serv. Report and Rear Axle Tech
Just wanted to give a big thanks to Steve at funrise. He did a great job getting my new rear axle to me with no hesitation. It took a little while to get things sorted out, but what do you expect when one guy is dealing with all of us whining about our broken toys . Anyways, on to the rear axle, I know where pretty much everything goes, but I have two questions: 1) I do not know where this goes, anybody have a pic or can tell me where to put it? 2) This is the splined cylinder piece that sits at the front of the axle, how does it stay in that little hole? Does a screw go through it or something? |
09-16-2005, 01:49 PM | #2 |
Pebble Pounder Join Date: Sep 2005 Location: Hamilton, On, Canada
the black thing is the new shifter, (yous is white) which slides the slider thing along the axle. the other thing should have a shaft that goes through it and when you screw on the diff cover it stays in place.
09-16-2005, 01:50 PM | #3 |
Newbie Join Date: Aug 2005 Location: Springfield
I don't get it... 1) In the top pic, you don't know where it goes, but in the bottom pic, it shows the piece. 2) The splined cylinder should have a rod that goes through it. It is then held in place by the bottom and top of the axle housing. If you took it apart and have a camera, I don't see why you are asking these questions. Take the front end apart and see what it looks like. The shifters are basically the same. |
09-16-2005, 02:20 PM | #4 |
Newbie Join Date: Aug 2005 Location: Chester
the shifter piece(black One) is actually two pieces. The part your showing is the bottom half. It makes it shift from 4hi to 4 low. And the bottom pic.there is a pin that goes al the way through it and slides into the little hole in the gearcase. When you put the top part of the case on,the pin will go into that part. I hope your not as confused by that as I am!!! hahha |
09-16-2005, 04:53 PM | #5 | ||
09-16-2005, 04:54 PM | #6 |
4runner666 and xtraflyr, thanks a lot guys, I know how to get this thing together now!
09-17-2005, 05:41 PM | #7 | |
On the replacement parts... You'd think that Funrise would send some kind of schematic to show where things go. Like a parts blow up with the part names listed. | |
09-17-2005, 06:58 PM | #8 |
it looks like the big pulley let go of the axle shaft.the pulley spins like crazy but the axle stays put!!! I was really loving this crawler too!!! maybe some JBV weld will do the trick?? and 911rc your welcome for the info.. later |
09-17-2005, 07:11 PM | #9 | |
Pebble Pounder Join Date: Aug 2005 Location: VT Burlinton
Stu | |
09-17-2005, 07:13 PM | #10 | |
WTF have we started Stu | |
09-20-2005, 02:23 PM | #11 |
Just grow up some,thats all they need to do, Stu... later, Frank |
