02-04-2009, 01:32 PM | #1 |
Pebble Pounder Join Date: Aug 2008 Location: pine
| r2d disconect
im ptting a r2s on my scaler and i was wondering if i should spray the gears with wd40 so they dont rust under water?
02-04-2009, 09:13 PM | #2 |
Rock Stacker Join Date: Nov 2008 Location: Under Your Ma Ma's Bed
You need to cover the gears with water proof grease. If you only use WD-40 you will burn the gears up. WD-40 stands for water displacement at the 40th trial. It works good for displacing water but won't lubricate the gears very well at all.
02-06-2009, 09:18 AM | #3 |
how does WD40 burn up gears?
