09-21-2005, 02:09 PM | #1 |
Newbie Join Date: Sep 2005 Location: U.S.
| rear slippage
i've searched and can't seem to find anything on how to fix my problem. whenever i try to climb somthing the rearend slips and continues to do so until i back off. when i opened it i noticed the lowrange gear was slightly out of alignment with the output gear. is this the problem and if so how can i fix it?
09-22-2005, 10:53 PM | #2 |
I had the same problem with mine. I did notice that the rear low range "pinion" gear had some missing teeth. I called Nylint and they are sending a replacement.
09-23-2005, 06:21 AM | #3 | |
Newbie Join Date: Sep 2005 Location: Baton Rouge
09-24-2005, 08:39 AM | #4 |
ya i did try pushing it over and it did work until i turned the truck on then it moved back over so im returning it today for another one. does anyone know if nylint will send metal replacement gears cuz if they did i would def pay to get them for my new truck.
09-24-2005, 12:06 PM | #5 |
well instead of returning it i just reversed the high and low gears so my high gear is now my low gear and ill call up nylint and ask for a replacement set. thx for ur help
