02-19-2009, 02:33 AM | #1 |
| Declassified: Griz's Miniclod 2.2 comp rig It’s finally time to post up my latest 2.2 comp rig build. I have been working on this idea for some time now and finally figured out how to do it last summer. I had the parts machined by Quicksand Off Road and first ran this rig at Nationals in 2008. I have been trying different setups since then and think I have finally found the right one. I went out a couple weekends ago to try my latest setup (using Cougars and not the HB Rovers) and it worked great. It was pulling off all but a couple of the “impossible” lines that Turtle was showing me and was keeping up with his Berg really well. I think with the tires I’ll be able to pull of all the lines now. The axle center sections are Tamiya Clodbuster and the axle tubes are my design. They make use of the Axial axle C’s, steering knuckles, rear straight axle adapters, and front and rear axle shafts. Overall width comes out to about 10.5” with the HB Rovers on MSD 4-Dyce wheels (TLT offset) and about the same using Panther Cougars on Axial 8 hole beadlocks. I was trying to set it up to run 3 ¼” of belly clearance for really good breakover clearance, but just couldn’t seem to get it to work right. The latest setup has 2.75” of ride height clearance with 3.25” fully drooped. To get this ride height I used 3.5” Traxxas shocks with the long rod ends from the HPI 85050 parts tree. It seems to work great; I wouldn’t mind a bit more articulation but a beer can (5.125”) seems to be good enough for now. The Reign Widemouth chassis turned out to be the perfect setup for the Miniclod axles. Not too much triangulation on the lower links, just enough to clear the motors. I really like the width of the chassis and the multiple mounting locations for the shocks and upper links helped me get this setup dialed in. A big thanks to Team RCCrawler, Holmes Hobbies, TCS Crawlers, Reign RC, and Montana Scale Designs for their support over the years. These guys are the best. Here is the parts list: Chassis: Reign R/C Widemouth Axles: Quicksand Offroad Mini-clod Lockers: Quicksand Offroad Mini-clod Front axle C: Hot Racing Aluminum SCP1901 Front steering knuckle: RC4WD aluminum X-0372 Front axle shafts: Axial AX30420 inner, Axial Ax30366 stub shaft Rear lockouts: Axial plastic AX80020 Rear axle shafts: Axial straight axle AX30421 Shocks: Traxxas 3760 3.5" Springs: (front) Losi 2" red 5128 Springs: (rear) Losi 2" orange 5129 Front upper links: Traxxas 5139 Rear upper links: Traxxas 5139 Upper link mounts: Thundertech Racing Front lower links: Traxxas 5319, 1 Jato rod end 5525 Rear lower links: Traxxas 5319, 1 Jato rod end 5525 Lower link mounts: Tamiya 9804179 Tie rod: Traxxas 5319, 1 Jato rod end 5525 Draglink: Traxxas 1842 rod end (2x), 6-32 all thread Drivetrain Motor Mounts: Thundertech Racing Pinion gear: Losi 10T front, Losi 9T rear Wheel hex: Axial green aluminum, AX30430 Wheels: Montana Scale Designs 4-Dyce, TLT backspacing Tires: Hot Bodies Rover, white compound Foams (front): Kreepy Red foams with 1/3 Proline standard foam on outer sidewalls Foams (rear): 1 1/3 Standard Losi grey Electronics Motors: Integy 45T ESC: Castle Creations Sidewinder Steering servo: Hitec HS5955 TG Dig Servo: Hitec HS 81MG BEC: CC BEC RX: SR 3001 Radio: Spektrum DX3 with 3 position switch mod Misc Body mounts: HPI A371 Steering servo mounts: Traxxas 2715 |
02-19-2009, 02:36 AM | #2 |
Naked pics.
02-19-2009, 03:02 AM | #3 |
no talent hack Join Date: Feb 2007 Location: Redwood City
I snuck a peek at nats but it just now made sense. I knew something wasnt right about the axles but couldnt figure it out. Are the lockers just a full gear replacement machined to accept the axial shafts? The truck looks good Grizz. Definately out of the box |
02-19-2009, 03:18 AM | #4 |
Quarry Creeper Join Date: Nov 2004 Location: Ground Hog Plains
That is absolutely bad***. I've been thinking of building a 2.2 clod with the widemouth chassis and now I think Im gonna do it.
02-19-2009, 04:50 AM | #5 |
Quarry Creeper Join Date: May 2005 Location: Crossville,TN
Well Grizz, that is some fine thinking outside the box and a great implementation of your idea. Gives me hope for finishing my own 2.2 Clod with perhaps borrowing some of your ideas. Carl |
02-19-2009, 08:52 AM | #6 | |||
The final inspiration for this came about when the Berg axles came out. I really wanted to go to the MOA because I have always been a big fan of the design, but I just couldn't see spending $300 to get them when I have 4 sets of Clod axles sitting around. Plus I didn't want to have to spend the money on new wheels when I have so many Axial type wheels. This was a way for me to do it without breaking the bank since I had most of the parts I needed. If you guys are interested in building a 2.2 Clod like this, the parts will be available soon. | |||
02-19-2009, 09:02 AM | #7 |
Boy howdy that is slick! Clod axles just seem tougher than the bergs, there is a lot more gear width.
02-19-2009, 09:13 AM | #8 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
That will never work. ;) I like your thinking Grizz. |
02-19-2009, 09:34 AM | #9 |
Sweet! I loved my Clod, it was just to damn wide! Looks like you fixed that! Now that tire designs have caught up(read taller), the Clods may make a return! |
02-19-2009, 09:43 AM | #10 |
Rock Crawler Join Date: Mar 2008 Location: lodi
ok ive never been into the moa because they were made outta metal it looks to me that the clod houseing is plastic right? so no more caught ups on the rocks? i cant beleave someone didnt think of this sooner this is going to kill the berg market way to go!
02-19-2009, 09:52 AM | #11 |
[HOONIGAN] Join Date: Nov 2005 Location: Grand Junction
I'm glad to see you finally let the cat out of the bag on this one.;) That thing is super bad ass for sure! |
02-19-2009, 09:57 AM | #12 |
Man thats awesome! I have been wanting to so the exact same thing for a little while now also. I was thinking of having a bolt on locker like the CPE one machined with the axial oval shaft hole machined in the center, or just the stock little hex size machined with the same hole in the center, that way it would work with other aftermarket lockers. I'm glad to see that you did it and it was possible. Are you or the machine shop considering making a run of these? |
02-19-2009, 10:02 AM | #13 |
'08 2.2 National Champ Join Date: Nov 2006 Location: UTRCRC
I'm glad you posted this up. It was easily one of the coolest rigs I saw at nationals. Nice work Griz!
02-19-2009, 10:06 AM | #14 |
RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
very cool truck you've build there.
02-19-2009, 10:42 AM | #15 | ||||||
I agree John, I've said for years that I don't think you'd ever have a gear problem with a 2.2 Clod. Quote:
Yes, we will be doing some production pieces now that I feel the bugs have been worked out. | ||||||
02-19-2009, 11:12 AM | #16 |
Quarry Creeper Join Date: Dec 2007 Location: Blue Jay
That is a thing of beauty and a work of art! Very cool! Scott |
02-19-2009, 01:35 PM | #17 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
Holy crap! THat is snazzy! Them axle tubes sure are sweet!
02-19-2009, 01:54 PM | #18 |
RCC Addict Join Date: May 2008 Location: On the rocks
Nice job Chris. Love the rig. Def something out of the box. Nice way not to break the bank by just using your head. I think im going to have to cut out my new grappler body like that. |
02-19-2009, 02:12 PM | #19 |
Something is not quite right with that truck, but I can't put my finger on it... What's going on here? What is that a Clod with some homemade axles and some kind of like, aluminum outer parts? It can't be a Clod, who would run a Clod in 2.2? What forum am I in? Non Crawler RCs? I just don't see that thing working at all. I don't like it. Chassis is pretty cool though. |
02-19-2009, 02:50 PM | #20 |
| whats funny is that's exactly what went through my head when i saw it at nats |
