02-20-2009, 12:59 AM | #1 |
Quarry Creeper Join Date: Sep 2008 Location: by a river
| best stering for a ax10
hi everyone just wondering what is the best steering servo for a ax10 i would like a servo with maxuim steering will ask any questions |
02-20-2009, 02:27 AM | #2 |
Rock Crawler Join Date: Oct 2008 Location: San Bernardino Mountains
This is like asking "what is your favorite color", there are so many good servos on the market to choose from & everyone has favorite. I will list what I run. On the comp rig I run a Hitec 7955TG, on the scale rigs I run Cirrus 704mg & my son is running a Hitec 645mg. The 7955 is about $100 & I love it but it is pricey. The Cirrus 704 & the Hitec 645 can be had for about $30 each, 1 warning about the Cirrus, if you run an fm/am radio I would go with a Hitec as I have had interference problems but if using a 2.4ghz radio then I like the Cirrus. |
02-20-2009, 11:34 AM | #3 |
hae thanks man im planing on doing a rebuil of my ax10.sterring servo,shocks,drive shafts,chassis,tires and tube body.im only 14 so it will take a a bit longer to build it up |
02-20-2009, 10:39 PM | #4 | |
Pebble Pounder Join Date: Dec 2008 Location: west carrollton
Hitec 5955 Losi crawler shocks (droop) MIP shafts HB Rovers on stock Axial BLs CC BEC Tekin ESC and 45t motor | |
02-21-2009, 03:16 AM | #5 |
Pebble Pounder Join Date: Feb 2009 Location: Stafford
I'm going to use an Ace 1015 servo. 200 oz/in of torque and a .10 transit time at 6v, I'll be powering it with a 7.4v lipo. Should be plenty, although anything rated at 300+ or 400+ should also be more than enough torque. Typically the gears in such servos are also stronger, however the reaction speeds of them are slower. With a crawler this may not matter, however the 1015 is the strongest servo I own and probably plenty strong for my first crawler...but I definitely may look into a 400+ oz/in servo in the future if I like crawling as much as I think I will If you're serious enough there's no reason to go cheap on a steering servo, the more torque the better. Titanium gears instead of metal or plastic = awesome. I can assure you that spending 100ish or more on a good servo initially rather than 30 on several crappy cheapo's will definitely work out for the better in the long run.
