Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: What paint to use?
Old 09-27-2005, 04:12 PM   #1
Default What paint to use?
What kind of paint can I use on this platic? Or whats the best to use anyway. I what it to hold up pretty good. I know it will get stratched, but I don't want it chippin off.
Old 09-27-2005, 04:39 PM   #2
Real Jeepers use Krylon.
Scuff the plastic with a brillo pad and the paint will stick betta.
geauxturbo is offline   Reply With Quote
Old 09-27-2005, 05:54 PM   #3
KRYLON FUSHION painted my 1:6 and love it easy to spray but bonds to dang nesr anything!!!!!!
Got Rocks? is offline   Reply With Quote
Old 09-27-2005, 09:29 PM   #4
i found rust-oleum hammered paint hold up very well.
roadkill424 is offline   Reply With Quote
Old 09-27-2005, 09:50 PM   #5
ill second the krylon fusion, but i scuffed mine up a bit and the $.94 red cheap spraypaint at wallmart has been holding up for a while.
skerb is offline   Reply With Quote
Old 09-28-2005, 07:29 AM   #6
STS
That's what I used on my links and they took quite a bit of dragging on the rocks before it came off. Good stuff.
STS is offline   Reply With Quote
Old 09-28-2005, 12:49 PM   #7
I used rustoleum white primer. That stuff sticks to anything...
I don't want it to look good, cuz if it looks good, then I'll care when it gets f***ed up!
rerock is offline   Reply With Quote
Old 10-27-2005, 02:33 PM   #8
i used the cheap testors model paint from wallyworld and it worked fine
twinkletoes is offline   Reply With Quote
Old 10-27-2005, 08:13 PM   #9
I used model master enamel for the gold and plain ole' krylon on the black parts (link in my sig)
Trike Kid is offline   Reply With Quote
Old 10-27-2005, 08:42 PM   #10
Another vote for the Krylon Fusion. Even if you don't rough up the exterior, it'll still stick with ease. It's still recommended you rough it up though for a top notch bond. Too bad i wanted my 1:6 black, and micheals only had fusion in metalic colors. So i did a base coat of silver fusion and taped off some areas and did a top coat of regular krylon flat black. In some places where it was too heavy of a coat at first, its kind of webbing up, but not noticable from a foot or 2
cherokee xj is offline   Reply With Quote
Old 10-28-2005, 04:44 PM   #11
another for Rustoleum, im used flat black as a primer and all is perfect so far
Sean is offline   Reply With Quote
