Thread: R2 Dual Dig
Old 03-08-2009, 09:43 PM   #1
Default R2 Dual Dig
Still require only 1 servo to operate both digs or does it require a servo to disconnect the rear and a separate to disconnect the front?
TBex is offline   Reply With Quote
Old 03-08-2009, 09:56 PM   #2
You can make single spring loaded on each end linkage and use just one servo.
I also use a MX3 radio on it so i have it set up with the toggle switch mod to work 4x4,rear open, rear locked just like normal and then can just toggle thru the model settings with the left right buttons to work the front when needed since the radio doenst lose bind when changing models.
other wise with a normal 3 way aux channel its front dig,4x4, and rear dig....though you can play with the courseness setting on the aux trim to get the full 5 settings
jfraymond is offline   Reply With Quote
