Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: 3/4 Rear Axle Flip?
Old 10-01-2005, 04:57 PM   #1
Default 3/4 Rear Axle Flip?
Here something I thought of at work. The Straight up / yo thread made me thank of it.
Old 10-01-2005, 05:01 PM   #2
It's a little small to read.
Lt. Dan is offline   Reply With Quote
Old 10-01-2005, 07:05 PM   #3
Sorry the pic is a little small.
Step 1: Turn axle 3/4 of the way up, Drill hole through axle housing
Step 2: Cut a pen run through the hole
Step 3: Run a long bolt through the pen and hook everything back up.
Step 4: Don't tighten the lock nut to tight. It will limit travel.
Doing it this will give you more clearance the flipping it, and you don't have to reverse your tires, cut wires , just make sure you don't drill through the motor, gears, wires and etc..............The rest you should be able to figure out.........
Old 10-01-2005, 11:19 PM   #4
I rotated mine 90* so that i ended up like this...flex is crazy and never get hung up...still trying to find a way to flip the front axle somehow.
skerb is offline   Reply With Quote
Old 10-02-2005, 05:55 PM   #6
move the front shock mounts together by just drilling two new holes. I did that on the front of mine and the tires will droop and tuck more than before.
Old 10-02-2005, 06:00 PM   #7
Notice how triangulated my front shocks are this these pictures and then in the last pic you can see where I drilled new shock mount holes more centered for the rear...but then realized that running the rear shocks closer together more parallel they flexed better...i had to move them outboard more in order to keep the tires out of the body.
Old 10-02-2005, 06:13 PM   #8
Its My Wifes Money!!!
John Deere's Avatar
Hey Skerb can you tell me how you made your rear shock mounts? I would like to know, so that I can do something like that. i like how you did that. I want mine to flex out more than it does. Also maybe someone can help me with doing at tummy tuke. I figured everything else out and I can just not figure this thing out.
John Deere is offline   Reply With Quote
