| | #1 |
| Newbie Join Date: Aug 2005 Location: Whitmore
| This is what I came up with for the steering problem. First I replaced the draglink with a straight piece of aluminum. Then after noticing the Knuckle flex I decided to put a little bolt in where the drag link attaches to the knuckle. This replaces the pressed in rivet. I first drilled out the knuckle a little deeper, actually almost to the bottom of the knuckle. This worked great until I sheared off the pitman arm. So then, the new pitman arm made out of aluminum. I used the dremel to make a square whole threw the platic pitman arm and inserted the aluminum one. This has to be the best upgrade so far. |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Jul 2005 Location: Provo
| what promblem do or did you have? |
| | #3 | |
Do you have one? The steering on these is not so great out of the box, because all the plastic pieces flex. | |
| | #4 |
| yes i own one that is a good mod maybe i will do it when i get my new belts looks good |
| | #5 |
| Quarry Creeper Join Date: Aug 2005 Location: Redding, True Nor-Cal, look on a map
| Nice upgrade!!! But I'm Pissed!!! That thing already seemed to steer better than my clod, and now this, ****, I'm Pissed!!! |
| | #6 | |
| Newbie Join Date: Oct 2005 Location: Kent
| | #7 | |
Sorry been a while since I've looked through the threds. To keep the new aluminum pitman arm in, was just a really tight fit. No glue or pins, just a nice "press" fit (AKA HAMMER) I've actually done this mod on two others with no failures and really good steering. Again I think it's one of the best mods for this thing.. larry | |
| | #8 |
| Pebble Pounder Join Date: Dec 2005 Location: Byron
| Hmm... Mine doesn't flex that much, It just doesn't turn at all! i'll hear the motor spinning, but theres won't turn till i move the jeep |
| Thread Tools | |
| Display Modes | |
