03-25-2009, 12:23 AM | #1 |
Quarry Creeper Join Date: Feb 2009 Location: Tucson, AZ
| Losi shocks
For you guys that are running Losi shocks, are you still using the stock springs? If not what are you using?
03-25-2009, 07:03 AM | #2 |
Rock Crawler Join Date: Aug 2007 Location: Columbia, TN
Some change them, and some don't. Personally I have a GC1 with them on it with stock springs, and there is absolutely no torque twist what so ever with it, and it handles great. Try them with the stock ones first to see how you like it, and if not change them. Things like that are all about what is good for you as a drive, not what is good for others.
03-25-2009, 08:42 AM | #3 |
RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
Whites in front, yellow in right rear, and Traxxas black in left rear. That is if you are looking from behind.
03-25-2009, 08:26 PM | #4 |
Quarry Creeper Join Date: Jul 2008 Location: looking for that perfect setup
i am running the stock springs all around perfect
03-27-2009, 09:37 AM | #5 |
Got my losi shocks last night, very nice. I do have one adjuster nut that is a bear to screw on to the shock bodies, it has to be wrenched on. I have checked and has not been cross threaded and that nut is difficult on all shocks, is this normal? Mounting the shocks: Anyone know why there are not pivot balls in the tops of these, seems a little odd. My plan was to use fuel tubing (cut about the same width as the Axial pivot balls) for mounting them to the frame, is this the norm? Thanks. |
03-27-2009, 03:27 PM | #6 |
no talent hack Join Date: Feb 2007 Location: Redwood City
it sounds like the adjuster nut is screwed up. you can get 4 of them for $7. i have a set where 2 of the bodies are screwed up, it kinda sucks yes, fuel tubing is normal. the reason there are no pivot balls is they were designed for different losi vehicles. they just got renamed as a crawler shock |
03-28-2009, 08:41 PM | #7 |
I got these on the my Axial and on the rocks. Have you ever heated up silly putty and poured it over rocks? That is what these shocks make my crawler look like. They are extremely smooth with 30wt and stock springs. I just need to tweek them to mellow out the torque twist. |
04-05-2009, 10:49 AM | #8 |
Pebble Pounder Join Date: Oct 2007 Location: BC Canada
Is anyone running tubing inside the shocks for limiters? I did that with my stock axial shocks but wondering if it is neccessary with the losi shocks.
04-05-2009, 01:31 PM | #9 |
Quarry Creeper Join Date: May 2007 Location: home
When i ran the Losi shocks on my Axial rig i used no springs in the front with internal springs from TCS(Droop). And i ran orange springs in the rear with a big fuel tubing limiter in the rear...Almost no Torque twist at all. 60 wt. oil For my berg i run the short 2" red Losi springs all around with interals also. 40 wt oil. |
04-05-2009, 01:42 PM | #10 | |
I use a bit of tubing on the outside to limit compression, it helped a lot. I'm running white springs in the front and yellows in the rear. I did the traxxas rod end conversion instead of using a fuel tubing bushing. I'm on my second season with these shocks, they just work really well. | |
04-11-2009, 09:21 PM | #11 | |
Newbie Join Date: Feb 2009 Location: ile perrot
| losi shocks with ax10 springs Quote:
runs goood..... | |
