03-29-2009, 02:52 AM | #1 |
Pebble Pounder Join Date: Apr 2006 Location: Mt Blanc; France
| 770'team sidewinder replica on yokomo cl axles
hello , I started a tuber on a pair of yokomo cl 1.9 axles : the side panels are printed on photo paper and than hot plastic laminated to keep them waterproof the brass tubing is lightweight and won't have to support the links : I 'll make a U channel skid plate to mount them ans the radio scaler set droop shocks : the steering wheel is a from shock flyer Last edited by SilverRidge; 03-29-2009 at 02:57 AM. |
03-29-2009, 05:28 AM | #2 |
RCC Addict Join Date: Jan 2008 Location: www.rccrawler.com
Great start!!! |
03-29-2009, 07:08 AM | #3 |
Rock Crawler Join Date: Feb 2008 Location: Anniston, Alabama
Looks pretty cool. But wont that brass tubing bend pretty eaisly?
03-29-2009, 08:53 AM | #4 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
nice work, i like scale tubers bassed off real ones ... tho i noticed that on the 1:1 he is running bfg krawlers, but you have that appears to be TSLs on the RC.. its details like this that make the differance :p
03-29-2009, 10:00 AM | #5 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
What keeps your droop shocks from coming apart when extended? how do you like those yoko axles?? are they strong? |
03-29-2009, 10:58 AM | #6 | |
the extremity of the inner tube is deformed to be wider ans fit the big tube inside Ø and once it's assembled the external tube is set to reduce the bottom Ø and the tube inside can't get out anymore without tools the brass tube is strong enough if you don't use too long sections without renforcements I've already made a pair of tubers like this and they never broke , remember it only have to support its weight and sometimes rollovers , all the linkage are mounted on the alloy skid for the tires the rc4wd rock crushers x/t 1.9 seem to be more scale but I've always heard the old rc4wd line up were hard like a bit of wood I didn't have run the yokomo axles enough to say if the gears are ok but the steering knuckles are for sure a weak point, they make aloy ones, the rest of the truck and axle housing seems fine most of the screw are mounted with threadlocker Last edited by SilverRidge; 03-29-2009 at 11:11 AM. | |
09-23-2009, 02:14 PM | #7 |
09-23-2009, 04:08 PM | #8 |
Rock Stacker Join Date: Mar 2008 Location: Mundelein
man i wish i had the time or skill to build a tuber... looks great man cant wait to see it done!
09-25-2009, 08:48 AM | #9 |
Hum; need some wheels, tires, and paint the cage iin black , it actually looks like a little toy Last edited by SilverRidge; 09-26-2009 at 11:52 AM. |
09-25-2009, 09:34 PM | #10 |
Quarry Creeper Join Date: May 2008 Location: Out in the country
| Nice!!!
I like tubers. Man your rig looks real sharp!!! |
