10-08-2005, 06:57 PM | #1 |
Quarry Creeper Join Date: Sep 2005 Location: Sydney, Australia
| going in water/mud?
can you run a tlt through water/mud? what do i need to do for this?
10-08-2005, 07:06 PM | #2 |
Quarry Creeper Join Date: Mar 2004 Location: 18" from computer screen
all I have to say is RBGerrish.
10-08-2005, 07:21 PM | #3 |
what?
10-08-2005, 07:28 PM | #4 | |
I wanna be Dave Join Date: Mar 2005 Location: Hiding from Goodall
Check out any post from the oregon crawling club, I swear they spend more time under water than they do on rocks Juat water proof your electronics and have a ball | |
10-08-2005, 07:47 PM | #5 |
RCC Addict Join Date: Mar 2005 Location: Saginaw
Yeah, the ORCRC crew can't seem to stay dry for long - just check out some of thier vids, it's good times. Mud/Water proofing has been discussed before, try and search for more threads about it. Basically, the most important parts you want to protect are your electronics. Seal up or ballon your elecronics, Plasti-Dip your servos. A motor will still run underwater without any kind of protection, but keep in mind, it may draw in a lot of dirt and stuff, and be sure to hit it with some motor spray afterwards, and make sure it is completely dry. As for batteries, I am not too sure how people deal with that - I mean, they will still work underwater, but they would probably get water underneath the shrink wrap and rust. You may want to balloon them as well. |
10-08-2005, 07:50 PM | #6 |
ok thanks can you just give me the links for the vids and ill do the rest?
10-08-2005, 08:31 PM | #7 |
Rock Crawler Join Date: Aug 2005 Location: Asia
you dont really need to waterproof the batteries ... as for motors, a little duck tape on the holes keeps dirt out.
10-08-2005, 08:40 PM | #8 |
i have done a search and i am confussed it says you sillicol on the circut boards but thats corrodes. i am not shure what to do. i dont want to run full underwater. just maybe a little more over the tires. so what do i ahve to do for my electronics? |
10-08-2005, 08:46 PM | #9 |
Rock Stacker Join Date: May 2005 Location: Ewa beach
here you go heres how i water proof my electronics hope this helps you My electronics are in a tupperware container and sealed with silicone then you can be doing this |
10-08-2005, 09:05 PM | #10 |
I'm one of those ORCRC nut guys.... I have no waterproofing, although I don't suggest my madness to everyone In this picture there lives TLT axles, Mashers, 'Pede tranny, Lathe motor, Super Rooster, Hitec 5645MG servo, Novak receiver and a cheap Ni-Cd pack. No water proofing... ORCRC is always looking for water... Old picture of rbgerrish's Maxx/Kong/water rig thing-a-ma-bob.... OR... check out www.ORCRC.com and watch our videos. For images of our adventures, http://www.rcrockgear.com/ORCRC/ <--Click that. |
10-08-2005, 09:11 PM | #11 |
sorry i dont get what you did. |
10-08-2005, 09:22 PM | #12 | |
Who, me? Or someone else that replied? Use the "quote" tool to help us follow you. RCC has gone over steps to waterproof our rigs a number of times, use the advanced search to narrow down your searching. Water + electricty = BAD news. ESC and water = a no no. Servos can handle a decent amount as the rubber o-rings tend to seal out most water, a dab of silicone or Shoe-Goo at the output splines can help keep water out. Motors will run under water fine, it's just when dirt/mud gets into the motor it'll start to go bad. Batteries can handle water fine, but try to keep them out of the wet stuff. It comes down to common knowledge... if you have some brains in your head, then you'll know what shouldn't get wet. You might have to re-build the gear cases, diffs, tranny and more if things get really nasty. I have NEVER taken my TLT axles apart and they have seen a ton of water and mud, been going strong and breakage free for over a year | |
10-08-2005, 09:27 PM | #13 |
so all io ahve to do is... 1. put a sealent such as sillico around the servo gaps and where the wire goes in? 2. ballon my reciver 3. i am not sure what to do to the esc. sorry aboutt he spelling i cant spell |
10-08-2005, 09:33 PM | #14 | ||
For the ESC you can stick it into a small tupaware container or a some sort of sealed box...but be sure it won't overheat. Best bet is to either mount it up as high as you can and make some lexan splash shields OR buy a waterproof ESC. There are several waterproof ESC's out there for under $60 US Dollars. Quote:
It's okay... you live on the butt of the world, being in Aussie-Land | ||
10-08-2005, 09:35 PM | #15 |
am i right with 1 and 2? whats is this plasti dip stuff? what do i do if i buy that?
10-08-2005, 09:37 PM | #16 | |
I know some have used it.... I've never purchased it, nor used it before. | |
10-08-2005, 09:38 PM | #17 |
ok so am i right with 1 and 2?
10-09-2005, 11:11 AM | #18 | |
Pebble Pounder Join Date: Aug 2005 Location: Stockdale, PA
10-09-2005, 12:32 PM | #19 |
I wanna be Dave Join Date: Mar 2004 Location: The Haunted Forest
Sean and I were just out in the water today. Balloons around the receiver AND speed controller, zip tie the ends, silicon seal the ends. Worked perfectly fully underwater. Stay tuned for one -sick- video! Ryan |
10-09-2005, 01:16 PM | #20 | |
Newbie Join Date: Oct 2005 Location: Mililani, Hawaii
