Thread: VXL trans spur adapter?
Old 03-31-2009, 05:34 AM   #1
Default VXL trans spur adapter?
Tried searching but couldn't find a specific answer, it's been a long time since I've messed with pede trannys. I have a steel geared VXL trans that has the round(not hexed) input shaft. It didn't come with a slipper clutch assembly so I want to put a spur adapter. Is there a specific spur adapter for this type of shaft? I know the old adapter, part number #3693 works on the old hexed shaft but does it also work on the newer round shafts?
thanks.
hawnmt is offline   Reply With Quote
Old 03-31-2009, 02:14 PM   #2
if im not mistaken they dont have a hard mount spur plate for the round shaft.. best bet is to try an axial spur adapter plate or get the slipper assembly off ebay for around 15$
NSR_CIVIC is offline   Reply With Quote
