Thread: black jack build
Old 04-11-2009, 10:05 PM   #1
Default black jack build
im sure there are lots of these but id like to share mine and maybe even get some good suggestions to improve, so with that being said here it goes
-tlt axles, with rcp lockouts, and 24mm wideners
-home made delrin bent lower links, still gotta make the uppers, made of 5/16 delrin rod with revo ro ends
-rc4wd r2 trans with disconnect
-3racing mini lst shocks stock springs in front and tamiya silver springs in back with 70wt oil all around
-mip axial driveshaft
-berg 3 spoke wheels with axial black bead rings, and narrowed badlands w/memory foam, 4oz weight in each front and 3 oz in each rear
-novak rooster with novak 55t motor
-servos, steering is a tower pro mg946r and dig servo is hitec hs625mg
and i also was wondering if anyone has used this trans setup on this chassis and if they had pics of how it was mounted?
heres some pics of my truck as it is now
rocksteadily is offline   Reply With Quote
Old 04-11-2009, 10:10 PM   #2
That looks good so far. That chassis is one of the best I have used. Dont forget to inboard the lower links for better articulation. I have mine outboard and they get scraped when I run. I need to fix those.
CRAZYACE63 is offline   Reply With Quote
Old 04-11-2009, 10:22 PM   #3
yeah i was gonna do that, but gotta wait till monday, no tools at my house so on lunch at work ill cut the skid to allow the links to in, and get some better triangulation
Old 04-11-2009, 11:26 PM   #4
I liked my blackjack alot, it worked great.
The Violator is offline   Reply With Quote
Old 04-12-2009, 12:10 AM   #5
is it better to turn the skid and trim it down to fit the r2 tans or better to trim the chassis? i dont know if id like to trim the chassis
Old 04-13-2009, 10:49 PM   #6
updates
today at work i turned the skid 90* and cut it to 2 3/4 to fit the r2 w/o having it hang over, and the mip driveshfts wouldnt fit the stock way either, i made the rear upper links outta 1/4 inch aluminum round stock, fits great with a little bit of a clock to the rear axle, and i was able to use 55mm axial links for the front. i had to make a servo mount/upper link mount to. put it all together and its good, wheel base is only 12 1/4 though ill figure how to make it longer.this thing has awsome balance, the trans is just sitting in there still gotta drill the holes for it
Old 04-14-2009, 11:39 AM   #7
FrankyRizzo's Avatar
Looks good.
Working on a second generation as well.
FrankyRizzo is offline   Reply With Quote
Old 04-14-2009, 01:05 PM   #8
Looks good!
Culetto is offline   Reply With Quote
Old 04-14-2009, 03:26 PM   #9
nice, i used to run those shocks on my blackjack, it makes for one hell of a stable rig.
as a matter of fact, culetto still has my Ti blackjack chassis.....
dieselfuel is offline   Reply With Quote
Old 04-14-2009, 06:58 PM   #10
Nice build, the Black Jack is a very stable and predictable chassis. I should be starting my new Black jack comp rig soon.
Tupers is offline   Reply With Quote
Old 04-15-2009, 04:31 AM   #11
today i got the motor/trans mounted, i had to shorten the driveshafts, made some body post mounts and put it all together, but the dig setup i have doesnt really work to well, ill have to figure it out. when im at a steep angle it doesnt disconnect. anyone have this problem with the r2 trans ? oh and ill post pics of the finish product later on today
Old 04-15-2009, 03:28 PM   #12
im pretty sure thats a common problem with the R2D trans. one of our local guys uses one and gets the same problem.
Old 04-15-2009, 04:21 PM   #13
so there is no way to solve that issue?
Old 04-16-2009, 12:29 AM   #14
heres some pictures of the finish truck
Old 04-17-2009, 09:28 PM   #15
got some tires in the mail the other day, so i cut them up and heres what i got now
