04-22-2009, 11:39 PM | #1 |
RCC Addict Join Date: Mar 2009 Location: hawaii
| r2 trans with dig binding
i have a problem with the dig on this trans binding, when im up vertically it never seems to disengage or re-engage, has anyone had this problem also? and if you have this trans and dont have a problem can you post pics of your setup cause maybe its just setup wrong?
04-23-2009, 01:57 AM | #2 |
Pebble Pounder Join Date: Apr 2008 Location: nor/cal
mine did it when it was brand new. after a couple of runs it shifts perfect. i know not much help, but maybe just double check the linkage and if it all looks good just run the rig a couple of more times. no picture, it is set up exactly like the instructions off the RC4WD website. good luck. |
04-23-2009, 02:54 AM | #3 |
Rock Crawler Join Date: May 2007 Location: Norwich
make sure the three bolts that hold the dig mechanism to the trans are tight - I know of few people that had them eventually fall out - ruined the whole trans.
04-23-2009, 07:49 AM | #4 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
How new is that R2D tranny???? what servo are you using....... if its new and everything is setup right, give it a little time to wear in.. a 645mg servo works great on an R2D.... |
04-23-2009, 03:24 PM | #5 |
i have used it for a little bit, not more than 30 hours though, and i am using a hitec 645mg servo. the shaft just torques up when the servo moves to disengage or engage
04-23-2009, 09:41 PM | #6 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
get the rocksmith bushings http://rocksmithengineering.com/ |
04-24-2009, 10:00 PM | #7 |
oh well, i cant figure it out, im just gonna junk this trans and get a axial one
04-24-2009, 10:22 PM | #8 |
Quarry Creeper Join Date: Oct 2008 Location: Madera
Don't give up man- it's just prone to binding. Which servo mount are you using? Combination of linkage parts is key too. I for 1 wouldn't point it up to 2 'o' clock like their website, but thats me. Nice n Level ! |
04-25-2009, 08:31 AM | #9 |
| Send it too me! Really they do work. I had to file a little to get a smooth engage/disconnect. The linkage angle on the stock servo setup is a little extreme (I made my own). And all mechanical digs "hang" sometimes. A bigger servo can fix about anything but it's really not needed.
04-25-2009, 01:44 PM | #10 |
i have this servo mount from rc4wd http://www.rc4wdstore.com/2/product_...roducts_id=517 and i made it so its not at the super steep angle it was flat and it still sucks, i tried a bunch of different angles and such, butit never works without a problem when im at a angle up on the rocks, it works ok when on flat groung and thats about it |
04-26-2009, 09:02 AM | #11 |
Quarry Creeper Join Date: Oct 2008 Location: Southwest VA
04-26-2009, 02:06 PM | #12 |
where did you file it?
04-26-2009, 07:11 PM | #13 |
I opened up the slot on the output that connects to the drive shaft. Dont open it too much or it will not stay engaged. This happened to me and I had to order these parts http://www.rc4wdstore.com/2/product_...roducts_id=469 and try again.
