04-25-2009, 05:40 PM | #1 |
Rock Stacker Join Date: Mar 2009 Location: paradise
| new to digs
how often is freewheel used when would you use it? thanks
04-25-2009, 08:53 PM | #2 |
Quarry Creeper Join Date: Jul 2008 Location: Asheboro N.C
Really I do not use free wheel much, I might use it once in a comp, but it is better to have it and not need it then to need it and not have it |
04-25-2009, 08:58 PM | #3 |
ive never had a need for it and i just use a 2 position 3rd channel works great
04-26-2009, 06:19 PM | #4 |
Quarry Creeper Join Date: Nov 2008 Location: Vacaville
i use freewheel in every comp, and when i power up my rig it defaults to neutral so in case it were to take off, atleast it would only be two out of control instead of 4 wheels. this is important if you use a low turn motor and lipo's |
04-26-2009, 06:22 PM | #5 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
i'm finding myself using free wheel more and more then rear lock................bob .... |
04-26-2009, 06:57 PM | #6 |
Quarry Creeper Join Date: Jan 2009 Location: El Cajon San Diego
All the feakin time. I use it on really tight turning descents, when side hilling and I don't want the rear to push and tip my rig over. I also use it to reposition my front end when trying to climb something steep. If I'm on loose ground, I free wheel and gun the throttle. It whips around better then if I try and use dig but it depends a lot on the terrain and the situation. It's all about learning how to drive your rig. If you didn't have it, you'd adapt anyway.
