05-06-2009, 04:21 PM | #1 |
Quarry Creeper Join Date: Jul 2008 Location: Galt
| Stripped pinion yoke set-screw!
The hex on the set screw in the pinion yoke on my front axle is stripped, and I can't loosen it. Does anyone have some tips on how I can remove the yoke from the pinion shaft? Thanks. |
05-06-2009, 04:33 PM | #2 |
Rock Crawler Join Date: Feb 2004 Location: Near Pittsburgh, PA
If there is locktite on it, take a soldering iron and heat it up...maybe you can get enough bite to get it out. I did that to mine and then drilled and tapped it for an 8/32" set screw that is easily found in any hardware store. Pretty sad that every "Hobby" shop I called didn't have 3mm set screws! If you can't get it out, just drill it out and retap with something a little larger. |
05-06-2009, 05:49 PM | #3 |
Newbie Join Date: Jan 2007 Location: Knoxville, TN
05-06-2009, 08:31 PM | #4 |
Rock Crawler Join Date: Sep 2004 Location: eureka
u can put as much sidways pressure on the allen wrench as you can and try to turn it . usually works
