05-10-2009, 11:29 PM | #1 |
Quarry Creeper Join Date: Apr 2008 Location: Garden Grove
| The (new) 1.9 Carbon Fiber chassis
Well,here is the new chassis. It is really my TVP tuber with the top rail cut off. Sorry Mike, I have crossed over to the dark side. I decided to run with the mini bug because the roll over factor is way better than my tuber was. I think I can get the body even lower by notching the area around the rear shocks. The front tires will hit the ground when it is on its top:-Pand that is a very very good thing for me. With my 35 turn motor and the new set up I hope to be looking good at the next two comps. |
05-11-2009, 10:45 AM | #2 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
Looks great! Going to Barona this weekend? |
05-11-2009, 02:21 PM | #3 |
| SD Comp
Hi Jake, I might as well. Only two comps left in this area for awhile.
05-11-2009, 09:51 PM | #4 |
no talent hack Join Date: Feb 2007 Location: Redwood City
as long as it still drives the same as it did last friday, this will be the rig to beat this weekend. I am still amazed at the lines it was pulling
05-11-2009, 10:36 PM | #5 |
It is the same rig, just a little less weight on top and the body is lower. Now it will have a new servo. The 1 year old 645 just stripped a gear |
05-12-2009, 11:39 PM | #6 |
| body shots
Here is a before and after shot of the body. It is legal and looks cool and works very well. The only thing I don't like are the weak shock ends. They pull out to easy.
05-13-2009, 10:53 AM | #7 |
Newbie Join Date: Jun 2008 Location: Socal
Looks good I hope to see it this weekend if you are going. I am hearing nothing but good things on your motors you have been making.
05-24-2009, 11:37 PM | #8 |
| Carbon Fiber for the stock axles
I had to build up a stock modified rig so I can test my 35 turn motors. I designed and cut out the CF plate and did a little tinkering with the stock plastic shocks and I also made some delrin lower links and skid plate. It all has come together well. I also modified the stock wheels as seen on RCC. I cut some PVC couplings on the lathe to fit over the stock wheels and it made a very good beadlock wheel. The cost for the wheel mod was .35 cents per wheel plus some lead weight for the inside of the wheel. I put on a 645 servo and all I need to do is electronics and then tune the shocks internal springs. I run droop so it sits low,plus I like the way droop handles. |
05-26-2009, 09:33 PM | #9 |
Rock Crawler Join Date: Jan 2007 Location: San Clemente, CA.
Nice build! Got a stupid ? though those are mini losi axles, right?
05-26-2009, 10:38 PM | #10 |
Yes, the last set of pics show the stock mini losi axles. Here is a pic with the body slammed down as far as it will go. Last edited by motorman1600; 05-26-2009 at 10:45 PM. |
05-26-2009, 11:19 PM | #11 |
Quarry Creeper Join Date: Jan 2006 Location: SLC
Nice work Bill |
