05-15-2009, 02:47 PM | #1 |
Rock Stacker Join Date: Jan 2008 Location: LAURENS
| r2
I recently bought a used r2 transmission but have a few questions. I emailed rc4wd but cant seem to get a response. I'm looking for a pinion gear. I know i need 8 tooth 32pitch gear but i dont know if i need a long one ore a regular length. Any help is appreciated.
05-15-2009, 03:27 PM | #2 |
i have had bad luck with them too they screwed me out of $45!:-(
05-15-2009, 07:15 PM | #3 |
Quarry Creeper Join Date: Oct 2008 Location: Madera
What are you putting it in? It comes w/ an 8 tooth. . . if you don't want to go over 1mph. . .
05-16-2009, 09:34 AM | #4 |
Web Wheeling Join Date: Jan 2005 Location: Twin Cities
Any standard 32 pitch pinion will work fine, you do not need anything special.
05-17-2009, 07:17 PM | #5 |
Its going in an edge chassis with wheelyking axles and a cobalt 7t puller motor. |
05-17-2009, 07:51 PM | #6 | ||
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
these guys have been above and beyond in my book, and have treated everyone i talk to fair. sometimes things get overlooked and mistakes can happen, so i am not saying that your case isnt true. try getting ahold of them again... more often than not they are willing to settle up and then some. then you will feel like doo doo for posting that they suck hell i even get emails on sunday nights | ||
05-17-2009, 07:56 PM | #7 |
05-17-2009, 08:40 PM | #8 |
support@rc4wd.com Join Date: Nov 2007 Location: Lancaster, Ohio
05-17-2009, 08:41 PM | #9 |
05-18-2009, 12:13 PM | #10 |
Newbie Join Date: Mar 2009 Location: southwest
i have the r2 and its a strong transmission the only thing is i snap drive shafts i even had the rings on the drive shafts so i was told to upgrade the driveshafts and i had a14 pinion gear in mine with a 55 turn
05-18-2009, 02:05 PM | #11 |
I'm running a 16T gear. The only issue I had was that the opening in the back of the tranny where the motor attatches to the tranny won't allow for the 16T gear to fit inside, so I had to remove the lexan cover on the front side, drop the pinion gear into the tranny and attatch it to the motor shaft,then bolt on the motor. It isn't too hard, but it is a slight PIA. I woudnn't use a 7T puller motor, the tranny won't last very long. Mine was screaming when I used a 500 Cobalt motor, so I had to switch to a 35T handwound motor. |
05-18-2009, 09:32 PM | #12 | |
Want to hear a 7T in an R2HD? Video track starts at 40 secs. in I swear the gear mesh is good ! Ive ran this since early winter with no troubles. Its just so noisy ! When you are on protected land you should try be quiet Last edited by roborg5000; 05-18-2009 at 09:37 PM. | |
05-18-2009, 09:43 PM | #13 | |
RCC Addict Join Date: Jan 2009 Location: Crawlifornia
I had the same problem. I just used the dremel to clearance the opening a little to fit the pinion. Just had to take a hair off. | |
05-18-2009, 10:17 PM | #14 |
thats a cool video what camera did you use not to get off subject... do they have a side mount or different mount for the r2 cause i got mine with the one on top |
