05-16-2009, 12:46 AM | #1 |
Pebble Pounder Join Date: Jun 2007 Location: Red Bluff ,California
| What is the overall weight of your crawler??
I have a Reign J2-TT based Axial. My total wieght is 5 lbs 10 oz. Am I in the ball park or am I on the porky side?? My wheels and tires alone weigh almost 3 pounds!! What are the rest of you guys and gals coming in at? Thanks |
05-16-2009, 04:55 AM | #2 |
RCC Addict Join Date: Jan 2008 Location: Mount Juliet
My Reign J2-TT with Bully Axles as a base weighs in at 8.25 pounds. About 3.25 pounds of that are wheels/tires. A pound or so in the motors (2). The Bully Axles are not light....so probably over a pound in there. The battery might be near the 1/4 pound mark. So with those major components, it is sitting close to 5.5 - 6.0 pounds. Still need to add the chassis, links (all of mine are solid 4mm threaded with 1/4" delrin sleeves....not light links.), ESC, Dig Unit, RX, Steering servo, Chassis bracing, body, wire, connectors, shocks & oil, and all of the steel screws/nutts to put it all together. The weight adds up quickly. |
05-16-2009, 05:13 AM | #3 |
Bully based Rig 7lbs 2oz
05-16-2009, 06:46 AM | #4 |
RCC Addict Join Date: Sep 2007 Location: Westland, MI
Vader Bully axled rig 6lbs 2oz.
05-16-2009, 06:54 AM | #5 |
CDW based Berg.....5 1/2 pounds. Hustler based super.....6 pounds. |
05-16-2009, 07:46 AM | #6 |
Pebble Pounder Join Date: Nov 2008 Location: Prescott
AX-10 based AX-10 was around 8, but now I got it down to 7 lbs.
05-16-2009, 11:27 AM | #7 |
RCC Addict Join Date: Mar 2009 Location: In a very dark cave can't you tell...
| My weight how dare you My AX10 ARTR comes in at a soild weight of 5 lb and 9 oz. Heavy enough, but not to heavy. Works for me, because its good enough for serious climbs and still can stop on steep downhills. |
05-16-2009, 11:48 AM | #8 |
Ok so im not too far off of everyone else. I have been working hard to try to get as much weight as I can downlow. I plan to go lipo and shed some more weight. Im running a 45 turn brushed motor and would like to keep my rig as nimble as I can with out sacrificing weight where I need it. As an added benifit I hope to lessen the load on my servo and the motor . What is the lightest setup out there? |
05-16-2009, 01:27 PM | #9 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
my tube frame tigress weighs in at 7.2 pounds and that with 6 oz in the front wheels and 5 oz in the rears...............bob .... |
