05-25-2009, 09:40 PM | #1 |
Quarry Creeper Join Date: Jul 2008 Location: SWEDEN
| Yoke pins / screw pins
Where can i find 3mm (M3) yoke/pin screws for driveshafts ?
05-26-2009, 09:17 PM | #2 |
RCC Addict Join Date: Nov 2005 Location: Kansas
I had BAD luck with my R2 trans (and PLASTIC stampede yokes)... I'd always strip out the screws, or even lose em... I lost my final spare, and couldn't do without crawling... I needed a FAST solution... so, being the redneck genious I am, I drilled out the pinion and shaft, and simply used a self tapping screw (similar to what is used in plastic) It holds awesome, and now, I not only have the peace of mind of having a somewhat better connection, but removing the yoke is EASY... now that it just takes a phillips screwdriver! I use steel yokes at the axles, but hardly have to remove em, though, I imagine that the same thing could be done to the axles... |
05-27-2009, 03:06 AM | #3 |
I use the stampede steel yokes and its for them i would like to find pins. I could mod them but i think there should be some place that sells them , just havent found them yet :(
