06-03-2009, 07:00 PM | #1 | |
| Worm gears + Super Rooster = no drag brake Quote:
I'm gonna wire the thing up backwards and see if it works so it coasts going forwards. I mean, I have no idea why that would happen at all. | |
06-03-2009, 07:31 PM | #2 |
RCC Addict Join Date: Oct 2008 Location: Alpine,CA
Wow, Your house is as empty as your beer. That video sucks. |
06-03-2009, 07:43 PM | #3 |
The esc is coasting to a stop, probably part of the programming that smooths out the glitching issue.
06-03-2009, 08:01 PM | #4 |
Either I'm incapable of running a controller in reverse, or flipping my radio TH channel to reverse and swapping the wires around made no difference. Reprogrammed the ESC a couple times, wired it one way, reversed this, wired it the other way, reversed that. No change. Still coasts only in reverse. JRH, glitch issue with a Super Rooster? Did I miss something? |
06-03-2009, 08:01 PM | #5 |
06-03-2009, 08:07 PM | #6 |
Pebble Pounder Join Date: Oct 2007 Location: BC Canada
Have you tried a different motor in there to see if you get the same effect, it may not be your super rooster but your worm gears?? Just a thought.
06-03-2009, 08:25 PM | #7 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
Well here is a question: Do the worm gears "push" or "pull" on the ring gear? That just might have something to do with it.
06-03-2009, 08:33 PM | #8 |
Rock Crawler Join Date: Sep 2008 Location: N.E. Mpls
its the post ionic feild effect double anti reverse syndrome.... lmoa Ok in english tell me if this makes sense ...???...???:? the evil brother of torque twist but in relation to the worm gear .... one direction makes this happen reversr that something else happens. now change those forces to the rotations of the worm gears?? makeing sense?? |
06-03-2009, 08:38 PM | #9 |
| That's what I'm thinking. If they rotated the other way, it might not do it... but might the way he want's it to.
06-03-2009, 08:49 PM | #10 |
mirror the diffs
06-03-2009, 09:03 PM | #11 |
YOu would have to change the threads... either from left hand to right hand.
06-03-2009, 09:51 PM | #12 |
SUPER rooster, my bad. That is weird. Can you push the rig by hand in one direction? |
06-03-2009, 11:40 PM | #13 |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
Cory, what if while re-programing, instead of giving full throttle, you go full reverse & then full throttle when it asks for reverse?
06-04-2009, 03:34 PM | #14 |
Newbie Join Date: May 2009 Location: Charlottesburg
Does the ESC have a push control setting? Worm gears should not coast, at all, ever, due to the design. There's practically no way that the wheels should move unless the driveshaft is doing the moving, or the gears are broken. |
06-04-2009, 04:08 PM | #15 |
Quarry Creeper Join Date: Apr 2008 Location: Garden Grove
It has something to do with the trim on the TH channel. I have the same thing happen with my FXR. Unless the radio is set to (0) before you sync it to the esc weird things happen. Try moving the trim one way and then the other. It kind of acts like a Push setting . |
06-04-2009, 04:19 PM | #16 | |
Ya what he said I knew there was something wierd but I agree...... With that note its electrical...... like the esc or tx isnt centering/going neutral. or voltage is being stopped slowly at the end like a bleed off of voltage | |
06-04-2009, 04:45 PM | #17 | |||
Hey! Thanks for the input everyone. I've been pondering about this most of the day today, and have come up with diddley squat! It's got to be something in the ESC. Quote:
Absolutely not. Quote:
It's a brand new DX3R radio, and it's all zero'd out everywhere. I thought so also, so I tried various trim settings. Nothing changed. I'll do it all over again, and change out the Super Rooster for a Tekin FXR since that's easy with bullet connectors. I will reset and reprogram and all that stuff before I try anything. Assuming everything will work normal, as in it will lock up when off throttle, I will then go back to the Super Rooster and make sure it still does what is happening. After that, I will change to a different motor. I have a 35 turn Integy in there currently. | |||
06-04-2009, 05:30 PM | #18 |
06-04-2009, 06:40 PM | #19 | |
Alright, so the first thing I did was change the ESC to a Tekin FXR. I got everything on bullets so it was easiest. Alright. WTF? The FXR acts the same way. It's got to be the radio. Brand new DX3R. Everything is at zero. Trim some forward in it and it still does it. As of now I'll stop caring, or swap the motor, or try my DX3 again. | |
06-04-2009, 07:01 PM | #20 |
Rock Stacker Join Date: Jun 2009 Location: Buford, Georgia
Can I have your Super Rooster ? PLEASE........... I have one allready & I need another... Harry |
