Thread: Axles for HR MOA
Old 06-09-2009, 09:37 PM   #1
Default Axles for HR MOA
I'm having a hard time finding a good strong axle for the HR MOA. Any help would be much appreciated. Thanks
ncalkrawler is offline   Reply With Quote
Old 06-09-2009, 10:14 PM   #2
Oliver Custom Knives
If you have some filing skills you can cut down Berg axles and use them. They are a bit longer , but much stronger.
DwaneO is offline   Reply With Quote
Old 06-09-2009, 11:07 PM   #3
Right on thanks I bought a set of bergs and thought there wasn't a way to make them work. But I just cut them down and used a dremel, worked perfect thanks.
Old 06-09-2009, 11:57 PM   #4
there's a member on here named letshandleit, he just got done making a batch of bully CVDs out of 4340 chrome moly. next he'll be working on berg an HR axles.
dieselfuel is offline   Reply With Quote
Old 06-10-2009, 01:21 AM   #5
Wel, so far I havetried a few different axles cut down. I even used Wheely King Axles cut down, but so far the best replacements I have found are the Berg Axleas cut down, but with any axle they have a weak point which is the OEM berg pin, in fact any pin I have put in has broken. However I am running 35t handwounds on 3s and a heavy trigger finger!! I do feel ALOT for secure using the berg axles, they are beefier..
Scott have you heard how well those Chromoly axle are holding up??
I will go and search for them..
The Real Dogman is offline   Reply With Quote
