11-18-2005, 02:14 PM | #81 |
Quarry Creeper Join Date: Jan 2005
OK now I have 2 nylints and one is needing a tt bad, I got my new chassis and imediatly took shocks off, stretched wheelbase to 18" and it has Clod Tires on it. I am building it for tought hill climbs mostly.
11-21-2005, 09:37 PM | #82 |
Pebble Pounder Join Date: Nov 2005 Location: South Range
I just bought mine tonight. I got the non updated chassis because I was sick of looking for a new one. Needless to say, I am sitting here looking at it and what you guys are doing. Being a 1:1 jeep owner (definitely not stock) I know how important CG is. Have you guys noticed any problems with the tummy tuck making you roll more due to a higher COG? Especially whoever it was (I didn't look back) that cut most of the underbody off? I read in another thread that the TT was like driving a jeep with rockwells on 31s (lol) and was wondering if moving the motor on the rear axle helped with this? Also, with the "crappy" wiring, did you guys replace it or what? What tends to break with it? Has anyone addressed the issue of the wires that run down to the axle? What happens when you get so much suspension droop, have you increased their length? My friend cut the large tabs off that limit down travel, have any of you done that, I noticed in a few pics some people hadnt. Sorry for so many questions, it is hard to modify a 150 dollar toy that you bought on a college budget. Thanks! Christian
11-22-2005, 06:10 PM | #83 |
Quarry Creeper Join Date: Aug 2005 Location: Crawlorado
Thats I didnt cut a huge amount off the bottom of mine I wanted to get clearance without killing the cog. Moving the motor just helps front of the axle clearance doesnt hurt cog at all. DONT cut the tabs off, I did that and it was a big mistake. I finally got mine working right again. I am using all the stock wiring at the moment and its been fine. I was just and idiot and messed up a wire but have now figured out the problem. And you dont need to lengthn the wires
11-22-2005, 07:19 PM | #84 |
RCC Addict Join Date: Jul 2005 Location: Provo
does inboarding the shocks make you lose clearance and does your upgraded unit have any difference in electronics over the old one?
11-22-2005, 08:52 PM | #85 |
inboarding the shocks lowers the belly alittle but thats it. I actually have outboarded mine alittle since the pics, makes it more stable and heres the new progress FRONT DIGS for the front, I had to cut the black shift thing so it would not change the axle to high. You cant just take it out because, they two switches that the red arrows are point to have to be pressed down (left for low right for high) to make the back gear changer work/shut off. closer shot of the cut, I then used hot glue to lock the axle in low. Keep it from poping out of gear when I have the switches in high gear now for the back I took an old piece of from an axle and cut it down to make a spacer so that, the rear can only slide over enough to be in neutral and not in high. I then glued it to the green housing shifted into low the arrow shows the gap that is need to shift it from low to neutral rear axle disengaged if I could figure out how to upload video I could post some. Its a pretty cool mod, I need to figure out a way to lock up the rear axle when doing digs, it would work alittle better oh and stock flex vs mine, after I limited the rear alot more (used to flex about an inch more before I limited it to keep the shocks together |
11-22-2005, 09:02 PM | #86 |
My friend didn't have trouble after removing those tabs, what was your problem? Also, how big is the video? I could probably host it for you on my school's account.
11-22-2005, 10:27 PM | #87 |
I have no idea how big it is, its quick time, if that matters. the problems I had was the shocks pulling apart more, they already did but it only made it worse, the axle would try and wrap under the jeep instead of climbing ledges. A center limiting strap solved the wraping but it made it just like with the tabs so there isnt really a point to cutting them |
11-22-2005, 11:04 PM | #88 |
ok so what i need you to do is post a pic of your rear shock setup...please
11-22-2005, 11:42 PM | #89 |
do what?
11-23-2005, 05:37 AM | #90 |
Pebble Pounder Join Date: Oct 2005 Location: AZ-Phx
i cut the taps to and have np with shocks pulling apart, but the rear does want to wrap under....nothing limilting straps wont fix |
11-23-2005, 05:39 AM | #91 |
how are your shocks no pulling apart I dont get it... Even if the shocks dont pull apart I really dont think all the extra flex does anything but look cool in posed pics. I got mine way to flexy and like I said made limiting straps and out boarded my shocks some. It works alot better now
11-23-2005, 05:49 AM | #92 |
i had to glue lil plastic taps at the ends of the shocks so they dont pull apart, but im looking for bigger shocks all together so i can inboard the rear shocks even more.
12-10-2005, 03:13 PM | #93 |
any updates camotj
12-12-2005, 01:32 AM | #94 |
just the digs was the last thing....other then that I just been drivin it. My focus is on the TLT |
01-11-2006, 11:53 PM | #95 |
Newbie Join Date: Oct 2005 Location: Kent
So how do you like the front digs? Does it turn pretty sharp? It seems like the back tires would just roll. Just a thought. Let us know how it turned out. Thanks.
01-15-2006, 02:24 PM | #96 | |
Newbie Join Date: Jan 2006 Location: South Central
01-16-2006, 01:35 AM | #97 | |
01-16-2006, 02:18 AM | #98 |
Hey CamoTJ, Do you have any updated pics? I haven't seen it for awhile with the body on. What broke on yours? And how do you plan on stopping the rear wheels from rolling during digs? I had some ideas, but don't think they would work well.
01-16-2006, 04:14 PM | #99 |
Newbie Join Date: Sep 2005 Location: Sintrul Poynt
Im pretty new to the rc thing, but could you some how cut the power to the rear motor when shifting to front only so the rear tires would drag? Instead of shifting from low-neutral keep the rear in low and have the neutral/high arm open a contact to shut off power to the back motor and drag the tires.
01-18-2006, 12:36 AM | #100 | |
