Thread: R&P Different Gear Ratio
Old 06-19-2009, 12:58 AM   #1
Default R&P Different Gear Ratio
Does anyone know if there are R&P gears that are different ratios from stock that fit the TC3/PTI axles?
TIA
HiloDB1 is offline   Reply With Quote
Old 06-20-2009, 08:25 PM   #2
Im not saying yes or no by any means but I have yet to see aftermarket ring and pinion ratios for any RC axles. but I may have over looked them the whole time
TBex is offline   Reply With Quote
Old 06-20-2009, 09:26 PM   #3
yeah overlooked..... axial has'em but i dont think anyone else does.
some different r&p ratios in metal would be nice! i'd put'em in my poulsons.
goobs is offline   Reply With Quote
Old 06-21-2009, 12:38 AM   #4
Axial, Kyosho, some Tamiya(IIRC) and you can even mix-n-match Associated BFT R&P into a X-Factor to alter the ratio too but that's pure old school technology from 2003/2004 days.
toyofast is offline   Reply With Quote
Old 06-22-2009, 10:47 AM   #5
Think I found what I was looking for
Old 06-22-2009, 06:22 PM   #6
you gonna share where u found them and what they are?
Old 06-22-2009, 06:48 PM   #7
Front: 3.231
42 Tooth Diff Gear
13 Tooth Output Gear
Rear: 2.167
39 Tooth Diff Gear
18 Tooth Output Gear
Apparently it was the last set the guy had. Im not sure what they are made of as Im waiting for my set to come in. Ill try to find out where he got them from or if he can get more.
Old 06-23-2009, 05:37 PM   #8
tad, that looks like the ones in my yokomo drift car.
stone_64 is offline   Reply With Quote
Old 06-23-2009, 06:13 PM   #9
Probably. I got them for my TC4FT that I use to drift. Counter dori FTW
Old 06-27-2009, 12:42 AM   #10
Hehe, 2004 is old school. Hehehe
Hey Tad. Could use a set if those. Any word from your supplier of any more that are in stock?
Da Hermit is offline   Reply With Quote
Old 06-28-2009, 04:53 PM   #11
I found a source for the 39 tooth ring gear, 18 tooth pinion gear but am still looking for the other set. Ill let you know what I find
Old 03-08-2010, 06:14 PM   #12
you didn't say what they are out of. what am i looking for at the hobby shop?
piratejake is offline   Reply With Quote
Old 06-02-2010, 10:51 AM   #13
I joined the Band!
Default R Different Gear Ratio
Hi John,If you multiply the gearbox ratio by the respective factors you mentioned, you will get the overall gear ratio. I set up a spread sheet in Excel with all the available gears and the overall ratios for 10/31 and 9/31 so that I can quickly convert from one to the other.
hectorloshuk is offline   Reply With Quote
