11-01-2005, 11:09 PM | #1 |
Rock Crawler Join Date: Sep 2005 Location: Columbia, SC
| Extra Low Gear Well, i had been thinking about doin it...and I finally had the parts for the swap... I used another black planetary gear ontop of the stock planetary box...so now my low is lower and my high is my old low...didnt take that much modification but turned out awsome...you can actually crawl now...without tapping the gas... given this is only really good for sticky rock like our rock course...and is absolutely worthless in dirt...but boy does it crawl...hopefully i will get a video up sometime soon. |
11-02-2005, 07:35 AM | #2 |
Post some pics. I want to give it shot. What all did you use? That would be perfect for 2.2's.....
11-02-2005, 08:33 AM | #3 | |
Quarry Creeper Join Date: Sep 2005 Location: Minneapolis
11-02-2005, 08:44 AM | #4 |
Newbie Join Date: Oct 2005 Location: Dayton
post pics, sounds cool!!!! |
11-02-2005, 09:18 AM | #5 |
Quarry Creeper Join Date: Oct 2005 Location: Chattanooga
Awsome, Looks like I'm gonna have to buy another Nylint |
11-02-2005, 12:20 PM | #6 |
you actually add another planetary set to the standard set...so that the planetary box is one set longer... This makes it where your old low is now super low and your high is your old low. I have a calc exam tonight...ill try to post pics tommorow. You only have to trim a bit of the case and it all fits perfectly...i love it. |
11-02-2005, 12:49 PM | #7 |
Rock Crawler Join Date: Aug 2005 Location: White Lake
That sounds really cool.
11-02-2005, 02:17 PM | #8 | |
I got a new Nylint in the mail the other day when my original broke. My son wanted it so he could play too, but now his is on his last leg also. Maybe when his is done-for; I'll tear his apart and see if I can make mine run again. I'll have to use his front axle for rear steer though. | |
11-02-2005, 02:29 PM | #9 |
Get those pic's posted............................ |
11-04-2005, 07:52 PM | #10 |
Ultimate RC Decals Join Date: Aug 2005 Location: San Antonio
so where are the pics??
11-05-2005, 03:11 PM | #11 | |
RCC Addict Join Date: May 2005 Location: Auburn, WA
11-05-2005, 08:00 PM | #12 |
The only way it would work is if you replaced the high gear with another low gear. But I still don't if that would work.
11-08-2005, 10:18 PM | #13 |
when i took pics the pics of the gearboxes were too dark...i got a video of one of them in action....here is it in Low LOW RIGHT CLICK _SAVE AS http://people.clemson.edu/~mkirby/wallykrawler1.mpg http://people.clemson.edu/~mkirby/wallykrawler2.mpg Im going to take another pic of the planetary tommorw. Last edited by skerb; 11-08-2005 at 10:21 PM. |
11-09-2005, 06:05 PM | #14 |
nice vids!
11-09-2005, 08:54 PM | #15 |
the twisty ties are temporary till i go pick up some more 3mm hardware i didnt have any long enough at the time... they are plenty strong though....im also thinking about putting a bolt through the center of the axle housing as the fit on this is tight even with extensive trimming as you can see...basically i cut and test fit...cut and testfit till it worked out...Also note...i did this on brand new axles so the screws that hold the axle housings together are fresh and strong still...i noticed after taking them apart a few times they get loose and can eventually strip out...but it hastn happend with this setup because there is acutally less stress on the gears and motor... drum roll.............. told ya it was easy...now i want to see a vid of someone with 2.2s on this setup...i may do it...may not...still decidign...tires are so expensive and i dont want to spend any more money. my total tally is stock nylint crawler $40 hardware for stick chassis $5 being able to climb vertical rock faces in a walmart rig...priceless |
11-09-2005, 09:13 PM | #16 |
dayum! im going to have to try this.. thanks for the pics and vid. anyone have some spare gearboxes they like to get rid of?? : |
11-09-2005, 10:51 PM | #17 |
Pebble Pounder Join Date: Nov 2005 Location: fairfield
Mine will be done tomorrow, just need to go get another truck. Maybe even do 4WS since i will have the front axle.
11-10-2005, 12:36 AM | #18 |
Now that I look at it...the reason i used the black gear was to have an opening for the axle gear to bite...i think you could acutally use an extra white one instead and put it before the black instead of after it...so you would have two whites instead of two blacks... only reason i was thinking about this...i happend to have a few planetary boxes laying around from when nylint sent me some...but one guy mentioned buying some planetarys...you could actually use a black planetary from one gearbox to lower the front...then use the white planetary from the same gearbox to lower the rear... if that makes any sense....I have been studying statics for 3 hours and its 2:40 am...so bear with me. |
11-10-2005, 05:27 AM | #19 | |
so what your saying is i don't need any more planetary boxes to lower the low? i can use what i already have? | |
11-10-2005, 07:38 AM | #20 |
you will need one extra planetary box total...and you can use the white section and the black section from it.... that is opposed to using the black section from two different boxes.. |
